Results 16 to 20 of 20
Thread: 18rg pistons in a 2tg?
    Too old to be a Grease Monkey
    Aug 2008
    Default Re: 18rg pistons in a 2tg?
    Thanks for that info W
    I am on a really tight budget here so I think that bore out and hone for the 18rg pistons is the go.
    I am not super concerned how much power this engine makes as it is only my first build. I would rather stay a little conservative and perhaps for the next one I build (if I do another) I may go the stroke etc way.
    I have a couple of blocks available but the one I want to use has a little damage and the 18rg pistons should cover that.
    I want to avoid having to mill anything down because I dont want to waste money so I am hoping that it just fits together.
    Nathan
    Carterton
    Did this back in the 80's when 3T parts were still expensive. Only had to mill the valve pockets and get a one off gasket made for the RG pistons.
    Mike
    71 TA22
    My Car
    Aug 2008
    Thanks 71. do you remember how deep you milled the valve pockets?
    I am trying to get away without milling the pistons? but will put it together and see if they touch.
    Although I am looking at a set of 89mm 3t pistons ready to go... just a few questions for the owner then we could end up going that way as this 18rg thing is a little hazey?
    Nathan
    Carterton
    Quote Originally Posted by Noof View Post
    It's so long ago I cant remember how deep we milled.
    If you have the 3T option (at 89mm bore) that is the better way to go.
    Your block from a 2TG or 2TGEU? If 2TG you will need to clearance the block and bores for the 3T crank.
    Mike
    71 TA22
    My Car
    Junior Member 1st year Apprentice rabbits's Avatar
    Aug 2006
    what car is it going into couldn't put a 18rg in? it would save you alot of time and money would also go hard
  1. 18RG info and specs need 2tg and 3tg
    Last Post: 08-04-2009, 05:29 AM
  2. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
