this laptops gone totally mad.. wouldn't log outOriginally Posted by 1JZ.747
apparently thats gone up a bit cost me $250 for one about 9 months ago and now it is apparently $380Originally Posted by 1JZ.747
http://www.toymods.net/forums/showthread.php?t=6402
If you look at most microtechs that don't have actual idle control with a proper valve actually connected to the output of the computer (as 90% of them don't and no microtech can control the factory idle stepper motors used on many engines like any decent ecu can anyway) you will see that to make them idle when cold they have a timing vrs engine temperature map so when they are cold they run more timing over the entire rev range to increase the idle.
yes it works but if your motor is tuned on the edge and someone jumps in and nails it when cold....
If you have a wax pellet type idle solenoid it will mechanically help compensate for the lack of idle control but lots of motors don't.
and for a ecu built in 2006 to not have any adaptive ignition control or adaptive fuel control or "proper idle control" and no one output that can be configured to drive a simple air bypass solenoid really doesn't count
my standard toyota 3sgte ecu from more than 12 years ago does more including the full sequencial injection
you must have a wax pellet idle control or something mechanical as well to make it idle cold and it sounds like you were very lucky to get a reconfigure that cheap
split personalities
