Results 16 to 30 of 43
Thread: 4age crank pulley, OE or Alloy ?
    Jul 2007
    Default Re: 4age crank pulley, OE or Alloy ?
    Quote Originally Posted by dangdang View Post
    Thanks jondee86, good info, my 82 is FWD though so RWD is unique, get that, but are the AW11 and 82/92/101 the same offsets??
    Yes they are, as any upgraded GZE crank pulley is interchangable between all versions of 4AGZE
    Jul 2008
    Auckland
    The best option with alloy gilmore drives is to do this.
    Stock OEM pulley machined down and the inside of the gilmore machine out.
    Now 9AGTE 410kw atw
    I haven't had a good look at mine, but I will tonight. Casey-G are the ones we have like this? I know that they aren't solid and do have a section in the middle like Bazda's pick. Just cant remember exactly what it looked like though.
    oregon
    there IS a difference between the offsets fwd - rwd... but only a little, it equals about 1/2 of a rib
    Jan 2007
    queensland
    i stand corrected
    Jul 2008
    Auckland
    Quote Originally Posted by RT40Corona4AGTE View Post
    The pulley was from Endeavor and it was solid alloy. This guy I know done this to it so it has a harmonic balancer
    Now 9AGTE 410kw atw
    May 2010
    TAS
    Cheers Trdee thats what I wanted to know, I can now order a aw11one in the confidence it will fit.
    Top info here guys as always, learned me some things on 4age pulley's balancers and drives.
    Now just to decide on OE or Ross...
    Quote Originally Posted by Bazda View Post
    I am sure that my one from endeavor is two piece? I am completely unsure as to whether it has the rubber in it or not though.
    I will dig it up tonight and throw a photo up for you Baz. I am sure it is two piece though.
    This is the kit I have. Note the crank pulley on the right at the rear, two-piece jobby! I am unsure as to the rubber though, will have to wait till I check tonight.
    Jul 2008
    Auckland
    Im sure its solid, esp for the price!, they made the side metal as the alloy ones they were making flogged out! Seen that happen.
    Now 9AGTE 410kw atw
    Baz - Ah OK that is probably the case. nonetheless I will confirm tonight when I get home from work and dig mine up.
    Sep 2009
    Mines 2 piece, steel center that bolts to the outer belt drive. But solid mounted all the same.
    Barry that pic on the last page is epic. I'm considering doing it! just for piece of mind.
    Yes Baz they are two piece, but no rubber. Solid Steel inner with aluminium outer. I knew they were two piece but wasnt sure on the rubber thing. I wasn't arguing with you mate, just thought that there might of been a chance of them actually doing it that way.
    I assume harmonic balancer would be better than it then regardless?
    Jul 2008
    Auckland
    Harmonic balancer hands down. I've spoken to them before about putting a rubber damper onto their alloy pulleys but they couldn't do it.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Maybe we should ask ATI to make them to suit 4age's, their pricing is better than the Ross ones.
    http://www.atiracing.com/products/da.../damtoyota.htm
    Now 9AGTE 410kw atw
  1. 4ac crank pulley same as 4age 16v?
    By s2k in forum Tech and Conversions
    Last Post: 23-09-2007, 11:12 PM
