I thought the 4AC had one of those thin V shaped belts and not the multi vvvvv like the 4AG?? Which would mean the pulleys are nothing alike.
Someone will confirm or deny this.
does anyone know?
Correct
4AC = small V pulley
4AG = fat ribbed bulley
if your talking about the timing belt gear then yes they are the same, if your talking about the harmonic balancer pulley then no.... see previous post.
My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.Originally Posted by merc-blue
BAD ASS 1986 MR2 - Finally Moving forward.
Originally Posted by DeftAnesthetik
Ahhhhhhh correct me if i am wrong .......But i thing the 4ac has different teeth on the gear.
4AC= square teeth
4AG= rounded teeth.
This is just off the top of my head from memory so i could be wrong------- But i dont think i am![]()
Correct,4AG has round teeth and 4AC square . Please dont post if yr unsure about something.
Dave
4AF 89 to 95 is square tooth and 4AF 95 to 2000 is round . Round tooth is the go , belts last twice as long. A typical round tooth belt will last 10 years with just about unlimited KLM on it . Ive seen 300000klm and never been changed , of course i wouldnt recomend it .
Dave
I put up that post cause i was pretty sure they are different....... Which is more than anyone else had done......Originally Posted by cambelt1
Atleast someone can confirm it from there![]()
I think Dave was referring to the poster above you citing incorrect infoOriginally Posted by 30psi 4agte
WoopsI'll be sure to double check my info in the future, I compared them between 2 pitures i have, i must have looked at the wrong one.
Sorry![]()
sorry all my bad, I went and had a look and admit that i am wrong, my problem is I have also worked on my 3A which has square teeth and i was confused.
