Results 1 to 10 of 10
Thread: 20v Alloy block boss on 16v with E58..doable?
    Junior Member Backyard Mechanic dangdang's Avatar
    May 2010
    TAS
    Default 20v Alloy block boss on 16v with E58..doable?
    Gday Fella's, was just wondering if the silvertop alloy block to bellhousing boss would fit my 16v block with e58 box? And if there would be any advantage in doing so. Just a question out of curiosity really as I have spotted them on the 20v's and have been wondering if tying my block and bellhousing together with one would be a good idea when running a lot more torque and power than standard?
    Cheers Toymodders
    Default Re: 20v Alloy block boss on 16v with E58..doable?
    well I could see how it could be a good idea to strengthen things up, but I am completely unsure if it will fit in your application though.
    Oct 2009
    16v blocks are the same as 20v blocks
    May 2010
    TAS
    Ok then, any one have any/one (are they a single piece or 2 halved?)
    I'm keen to try it/them on my 4agte I'm building.
    Administrator Backyard Mechanic
    Jul 2009
    FWD won't need it as there is ample support by the 3 engine mounts anyway...
    But yes it should fit
    Feb 2007
    Timaru
    Quote Originally Posted by shrike View Post
    NO. They are not. The 20V block has a different shaped sump to a 16V.
    They do not interchange and are out by quite a lot.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    May 2010
    TAS
    Ample support from the three engine mounts I can understand BLK20v, but why did Toyota add these for the 20v even though they were all FWD anyway?? Has to be a basic engineering premise for them surely not just because they look good?
    So as the shape of the 20v sump is designed to go around the boss DX20VT and the 20v sump wont fit the 16 v block then the boss wont fit the 16v unless the sump is modified?
    Simply the 20v boss fits the 16v block but doesn't clear the 16v sump?
    As a curiousity/aside, 7AFEs have two-piece sumps with the upper alloy part extending all the way to the bellhousing as below:
    Looks like it would provide similar benefit (along with increased oil capacity? 7AFEs have 700cc more sump capacity than 4AFEs, not sure about 4AGEs though), assuming it bolts up to the 16v block?
    Junior Member Grease Monkey KENut's Avatar
    Jun 2009
    I thought 16v supports had 2 bolts onto the block? Therefore I cant see that 20v one being much more useful/strong with a single bolt per side.
    Feb 2007
    Timaru
    Quote Originally Posted by Hiro View Post
    The 7AFE two piece sump fits the 20V shaped block, and does not fit the 16V blocks.
    - KE70 Corolla Dx -
  1. 3S-GTE Block Variations
    By twentyEight in forum Tech and Conversions
    Last Post: 04-05-2014, 11:04 PM
  2. 2TG head/ 18R block
    By quikestsilva in forum Tech and Conversions
    Last Post: 08-06-2007, 01:36 PM
  3. 2TG head onto 3TC block...need help
    Last Post: 15-05-2007, 08:07 PM
  4. 4age Block suitability
    By 306rwd in forum Tech and Conversions
    Last Post: 27-02-2007, 04:22 PM
  5. boss kit/horn
    By badboysoulja in forum Tech and Conversions
    Last Post: 02-10-2006, 10:31 PM
