Results 1 to 4 of 4
Thread: 1JZ TPS Sensor type
    May 2007
    Default 1JZ TPS Sensor type
    Ok so after lots of issues with my car ive had someone tell me the JZ TPS is a switch type and thus when wiring up a microtech to it you should only connect 2 wires brown and grey...
    previously ive had it connected as a Variable Resistor Type which basically means connecting all 3 wires...
    For those who dont know and want some extra info on how it works it is as follows...
    Switch type
    At idle it will be closed and the ground circuit will be connected and then upon opening the throttle it breaks the connection and becomes open circuit...
    Runs 5v in and a signal wire back out as well as a separate ground wire... basically it gets a 5v supply into it and has a variable resistor inside the tps which sends a varied signal between 0 and 5v back to the ecu to give a precise throttle position...
    this is all to my understanding and could be wrong but thats as i understand it...
    So being that its a 4 wire sensor ive been thinking it would have to be a variable resistor type...
    any ideas?
    Nov 2009
    Default Re: 1JZ TPS Sensor type
    I'm keen to find out also... I have a microtech hooked up to a 1jz and I'm wondering if the TPS is wired properly (engine runs like crap for a few different reasons atm)...
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Check about halfway down this page:
    http://www.toymods.org.au/forums/showthread.php?t=23175
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    May 2007
    Cheers mate... should be a good help
    come to think of it i think i possibly have that somewhere on one of my computers
    which one or where however is a different thing
  1. TPS to suit universal billet throttle bodies
    By RT40Corona4AGTE in forum Tech and Conversions
    Last Post: 15-06-2009, 08:45 PM
  2. 1jz tps
    By audi2nr in forum Tech and Conversions
    Last Post: 27-04-2008, 04:21 AM
  3. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  4. 1jz tps
    By audi2nr in forum Engine & Driveline Conversions
    Last Post: 24-04-2007, 02:10 PM
