There are two knock sensors on the block (front and rear on the block).
One oil pressure, it is in the middle on the block; but the oil pressure sender should only goto the dash, not the ECU...
The water temp will be the two wire one (the 1 wire one will be the dash sender).
R154, yes the drivers side rear is the speed, the middle passenger side is the reverse lights.
If you have any doubts you can use the ECU pinouts to trace the wires back / find out what they do!
Cant decypher which (colour) wire on the tps does what function.
