Results 1 to 4 of 4
Thread: 4AGE Alternator charge light query...
    Sep 2009
    Default 4AGE Alternator charge light query...
    I have a hacked apart dash in my sx Seca, i only have the factory fuel, speedo and tach left, all other gauges are stand alone autometer units.
    I am yet to install/wire the charge light circuit. I don't really need the light itself installed so i was curious to know if i can wire it straight o IG+ with a resister inline (if i even need that) or even something i can install out of the way/easier like a LED with a resister so the circuit is always connected when IG+ is on just to eliminate the possibility of the factory style globe breaking on me/makes it easier to wire up in whats left of my dash.
    I only ask as i have none of the factory plugs installed and am only using sender/sensor wires i need i.e fuel gauge circuit and such.
    Any info is appreciated,
    Case
    Default Re: 4AGE Alternator charge light query...
    just install a light. Put IGN+ on one side, and the other side goes to charge light of the alternator.
    You can even use a panel mount globe such as these from Jaycar:
    - holder: http://www.jaycar.com.au/productView.asp?ID=SL2620
    - globe: http://www.jaycar.com.au/productView.asp?ID=SL2652
    Sep 2009
    Thanks whitzl,
    Do you think maybe i can just use a resister in parallel with an LED? makes it easier to install that's all.
    Sep 2009
    nvr mind im forgetting my basic electronics...
    i bought one of them jaycar globes/holders works a treat
    Last Post: 17-06-2008, 08:53 PM
  2. Alternator Wiring 4AGE -> Ke30 Loom Solved
    Last Post: 11-09-2006, 08:09 PM
  3. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
