Results 1 to 15 of 21
Thread: 4ag Main Bearing stamp
    Default 4ag Main Bearing stamp
    Hi All
    I am ready to order Main and Rod bearings for my 4Agze. When I checked the Mains for stamps I found that they differ (2, 3, 3, 3, 4)
    Is this normal? On the sites I have looked at their seems to be no provision to choose Mark 1 2 3 4 5?
    Please share your thoughts..
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    Default Re: 4ag Main Bearing stamp
    Yes all the bearings will differ.
    Toyota does I think 5 sizes for the mains. #1-5
    3 sizes for the big ends. #1-3
    If you buy from a Toyota parts dealer they will ask you what # bearings you need.
    The difference from #1 to #5 bearing is 0.0006" (0.6 of a thou).
    #5 bearing having the thickest wall center. #1 having the thinnest.
    If you buy aftermarket bearings they are always made to the biggest clearance to be on the safe side therefore to #1 bearing of the Toyota specs.
    Now 9AGTE 410kw atw
    Thanks Baz
    Good info!
    Jul 2007
    Quote Originally Posted by Bazda View Post
    so if you want it to be "toyota tight" (as drifty says ) then your best bet is to get the bearings from toyota as they are the only ones who make bearings to all the right specs? no aftermarket people make them to all five sizes?
    well i guess you could machine the crank to suit the aftermarket bearings, but yeh. sorry, thinking out loud lol
    Jul 2008
    Auckland
    Thats correct, if you want it to have perfect clearances you can only get Toyota ones.
    Or you will have to get OS bearings and grind the crank.
    No one makes them in all 5 sizes except Toyota.
    Now 9AGTE 410kw atw
    Yep, I have some tgp bearings coming from Lithia Toyota Oregon. The only website I have seen so far that gives Mark 1, 2, 3, 4, 5 option. Mark 1, 2, 3 option for the rods.
    Tallahassee, FL USofA
    Quote Originally Posted by old_mr2 View Post
    Is this normal? Please share your thoughts..
    Yes.
    The factory grades are great, IF you've got a new/slightly used block & crank, otherwise with 15+ year old & worn parts, the grades are pretty much useless.
    Also, it isn't just the grade of the block's mains but the cranks & when combined that gets the bearing number, right?
    oregon
    Well I am worried about my Main Bearing Caps. I dont believe they are marked in order and I didnt mark them when I removed them! How can I know for sure which cap goes where?
    Jul 2008
    Auckland
    main bearing caps are always marked by toyota. 1-5 with arrows.
    Now 9AGTE 410kw atw
    Low rep 1st year Apprentice
    Aug 2010
    If my failing memory serves me correctly you can use the TRD bearings of the same spec with better oil grooves?
    Jul 2008
    Auckland
    The TRD ones will have chamfered oil grooves like the Toga bearings and ACL race bearings.
    Toga
    Toyota OEM
    Now 9AGTE 410kw atw
    Aug 2010
    Am i also correct by saying that there is a colour code?
    Jul 2008
    Auckland
    On the Toyota OEM bearings there are no colour codes. just Numbers.
    Now 9AGTE 410kw atw
    Checked this and you are correct. Phew!
    I am just waiting on my crank balancing, then will be ordering.
    Main 2, 3, 3, 3, 4
    Rod 2, 2, 2, 2
  1. Spigot bearing removal pictures.
    By maurice c in forum Tech and Conversions
    Last Post: 18-09-2010, 11:26 AM
  2. 3S-GE GOING Main bearing....?
    By blah_00 in forum Tech and Conversions
    Last Post: 14-11-2006, 01:12 AM
  3. Bearing kits for W50 and P51.
    Last Post: 21-10-2006, 01:37 PM
  4. Bearing Compatibility List
    Last Post: 05-10-2006, 08:23 AM
