Results 16 to 21 of 21
Thread: 4ag Main Bearing stamp
    Default Re: 4ag Main Bearing stamp
    Quote Originally Posted by troysota View Post
    Am i also correct by saying that there is a colour code?
    honda do this for motorbike motors.
    I am just waiting on my crank balancing, then will be ordering.
    if they linish or otherwise grind the crank, the number code on the crank will be wrong.
    Find the TSRM for your engine as it should have the tolerances that relate to those marks.
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    cool ! when i pulled my motor down i thought it was made up of spares ! ( we used to stamp all the rods and mine were full of 2 s, except no 2 ! )
    time consuming and messy but you could order one bearing and a packet of plastigauge ,then order bearings to suit but hey if the crank looks worn its gonna be more than a few thou
    and im sure youd send it off
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    Jul 2008
    Auckland
    The rod caps are not marked, only the crank caps are marked.
    You will have to keep the rods in order and mark them.
    And plastigauge will not work. Your talking about 0.6 of a Thou! between the smallest bearing to the biggest. Plastigauge only works in 0.5 of a thou increments, even then its not super accurate its just to make sure you have around x clearance.
    You will def need a inside and outside mic if you want the specs to be bang on.
    Now 9AGTE 410kw atw
    Genuine Hotty. Conversion King old_mr2's Avatar
    Well, I ordered before seeing this post. My crank has been linished. Should I be concerned? I ordered exactly what was stamped onthe back of the Main bearings 2, 3, 3, 3, 4...
    Jul 2008
    Auckland
    A quick polish or linish should not really effect it that much at all. I would not be too concerned. Just points of a thou more clearance.
    Now 9AGTE 410kw atw
    OK Cool, thanks again.
  1. Spigot bearing removal pictures.
    By maurice c in forum Tech and Conversions
    Last Post: 18-09-2010, 11:26 AM
  2. 3S-GE GOING Main bearing....?
    By blah_00 in forum Tech and Conversions
    Last Post: 14-11-2006, 01:12 AM
  3. Bearing kits for W50 and P51.
    Last Post: 21-10-2006, 01:37 PM
  4. Bearing Compatibility List
    Last Post: 05-10-2006, 08:23 AM
