Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: 1jz gte vvt-i tuner
    Default Re: 1jz gte vvt-i tuner
    Moroso slide calculator indicates that with 415hp and 3610lb you should be trapping 114mph............. and 11.5 ET if you get it all perfect.
    You are right, MPH shouldn't change a great deal between a good launch and a great launch, infact runs with considerable wheelspin often yield a HIGHER trap speed than a good clean hard launch.
    Aug 2009
    and also the moroso is flywheel hp not rw ?
    Never seems to work accurately that way though.......... using hp at the wheels for our turbo cars seems to be much closer to reality, its proved to be pretty much spot on for the majority of car's i've run through it.
    My corolla for example, 350rwhp, 2600lb, predicted ET 10.95 @ 121mph............ I actually ran 10.98 @ 122mph with a 1.49 sixty foot time.
    I think the reason is that the hp figure is supposed to be an average hp for the revs you use between gearchanges.......... rwhp therefore is probably pretty close to average flywheel hp. Or at least that seems to be the way it wants to work
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  2. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
