Results 16 to 30 of 33
Thread: 1jz gte vvt-i tuner
    Aug 2009
    Default Re: 1jz gte vvt-i tuner
    only 1.9 ft lb less peak torque it makes peak torque sooner now and holds later in the rpm hence
    the higher power , since power=torqueXrpm/5252 roughly (with ots of other variables)
    Quote Originally Posted by senn View Post
    interesting that on the dyno sheet in november you're making more power but less torque...
    Yeah the graphs are a bit deceiving at a first glance as in the first graph it's only rev'ing to about 6k1, in the second its about 7k4...
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2009
    ok think i found the cause of slow 1/4 mile , my turbo is whining really bad and car is now undrivable
    so off that comes and have to send back to manufacturer , its only done 16,000 km
    and 13,000 of that was less than 13psi
    don't worry about the boost its run mate, they can take a lot more than that. Most turbo failures are either caused by physical damage to the wheels, or oil feed problems.
    Either way though, sucks to be you man, sorry. Hope you get it sorted quickly and get back to the track for some fun, and a proper time & trap speed
    Aug 2009
    thread revival
    i replaced turbo with a garrett gtx3076r
    and i now have 311rwkw but still doing slow drag times
    running 255 50 16 toyo tq drag radials on 14psi tyre pressure i ran
    a 12.66 @111.94 mph 1.975 60'
    for the power i should be doin 120mph
    why am i still failing 12 months later?
    what am i doing wrong?
    Maybe you're just a shit driver, or there's a coke can stuck under the accelerator haha
    What are you using as the basis for expected MPH? Moroso drag calculator or similar?
    Its a pretty heavy car man, are you really unhappy with a 12.66 on a pretty slow 60' time?
    120mph puts you pretty close to a ten second pass with all other aspects spot-on (perfect launch, shifts, gearing etc)........ that's a quick pass for a heavy car.
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Ha Ha that could be a lot of your problem the first 60ft is the most important section of your quatermile
    How hard are you leaving the line and are you getting any wheel spin
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    Aug 2009
    comparing mph to what tuner said it should do , and also every online calculator i can find
    trust me its not easy gettin a manual 311rwkw 1640kg car of the line fast but
    everyone says trap mph is the true hp which puts me at 245ish rwkw? and i have dyno printouts from two different dyno's showin
    over 300kw,
    i know dyno's not 100% accurate but over 20%out surely not
    so where am i losing power?
    Aug 2009
    leave the line at 3k quick clutch out not riding it ( twin plate clutch to expensive to ride ) controlled wheelspin in first but still hauling arse, (as in not sittin there frying ) got shit vid that got downsized by mms if that helps
    Thats the problem then you need better grip then bigger rpm take off
    In my celica it only had 170 rwkw and ran a 12.3 at 110mph but I was running 26x8 slicks and leaving the line on the limmiter 6500rpm with no wheel spin at all and a 1.6 60ft
    The slicks gained me a 1.1 seconds over street tyres
    Administrator Backyard Mechanic
    Jul 2009
    Low tyre pressure would also slow you down... get good tyres
    Aug 2009
    hahahah get good tyres , i'm running 255 50 16 drag radials
    Aug 2009
    its not the 12.6 i'm un happy with its the mph that points to lower power than i have
    Dec 2008
    western australia
    happy dyno ..
    Aug 2009
    so two happy dyno's?
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  2. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
