Hey mate, what sort of oil feed line do you plan to use? A braided teflon hose? If so, Motorsport Connections sell restrictors to suit the Garrett BB turbos that slip in to the hose end. Without this I had a little bit of oil finding its way into the exhaust under certain conditions with a GT3076. Talk to your turbo supplier to be 100% sure in your application though.
Much of a muchness as to which oil feed hole you use, depends on which has the neatest path for the hose to run to the turbo I guess.
10mm is a bit small for the oil drain, aim for 16mm (5/8", dash-10) or bigger.
Phil
