Results 1 to 3 of 3
Thread: 1ggte - code 12 and code 14
    Aug 2009
    Default 1ggte - code 12 and code 14
    hey guys.. my cars running like abit of a pig atm and im pointing the fingers at dirty injectors atm but i pulled some codes thort id ask some questions..
    12 - G, NE signal number 1
    could be
    -Open or short in crankshaft position sensor, camshaft position sensor No. 1, No. 2 circuit.
    -Crankshaft position sensor
    -Camshaft position sensor No. 1, No. 2
    -Started
    -ECM
    14 - ignition signal
    No IGF signal to ECM for 4~7 consecutive IGT signals with engine speed less than 3,000 rpm.
    could be
    -Open or short in IGF circuit from igniter to ECM
    -Igniter
    -ECM
    now what im not sure is if these codes are the correct problem, im assuming the car would run without these pulses etc... anyone know what IGT signal to ECU means?
    just runs like a piece of shit under boost.. just thought id ask if anyone has similiar trouble before i pull the injectors out..
    Aug 2010
    Default Re: 1ggte - code 12 and code 14
    Hi Pandaah,
    Do you still have this problem? If so I've been looking into the same sort of issue just with a 22RE not a 1GGTE but on this thread
    http://toymods.net/forums/showthread...ferrerid=25128
    The same problem has been explained so your problem maybe your igniter/coil as well.
    Hope this helps
    Jerry
    Aug 2009
    tried the ignitor, wasnt the issue.. i think im having problems with a worn distributor shaft cos timing is bouncing 4 degrees up and down on idle.. havent been ass'ed replacing it yet ive been too busy..
    thanks for your help!
  1. Help - Error code 22 on MX83
    By seanoz in forum Tech and Conversions
    Last Post: 23-08-2010, 12:41 PM
  2. 1GGTE Gen 1 Trouble code 54 / transmission in limp home mode
    By Javal in forum Tech and Conversions
    Last Post: 26-07-2010, 09:15 PM
  3. 1jzgte fault code 13.......HELP!!!
    By keca18 in forum Tech and Conversions
    Last Post: 16-06-2009, 05:20 PM
  4. 1GGTE Fault code
    By Rosie in forum Tech and Conversions
    Last Post: 09-06-2008, 10:08 AM
