Results 31 to 45 of 57
Thread: Rear Brakes Locking before front JZA80
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Re: Rear Brakes Locking before front JZA80
    Thank you for the detailed explanation OC, greatly appreciated! (will rep once I've spread enough to rep again).
    Glenn - If you're looking at swapping to the 2 piston rears you could try import monster, there's always a few sets of 2nd hand rears selling separately on yahoo.jp... Also try Koffee_black's trader forum on the supraforums (Gorilla Industries), he was selling reconditioned callipers a while back.
    Quote Originally Posted by 1jz68u View Post
    not as easy as it sounds. Where am i going to find just rear calipers? And im not sure i want to buy a set just to get the rears then have a spare set of fronts??
    Wonder if i can get just rears from toyota?
    Sure is. As you said, just buy them from Toyota. I got brand new front and rear calipers, freighted to Perth from NZ for $1100. I'd say a large chunk of that was the fronts. I then sourced the rotors locally for like $200.
    Quote Originally Posted by midnight_purple_GA70 View Post
    rory at rutherford and bond should be able to hook you up with a set of rear calipers...
    he is in nz but prices are generally very competitive/awesome
    [email protected]
    thats his email address... you will need either part numbers or vin/chassis of a car with the 4/2 pot brakes
    This is the man I got mine from
    Junior Member Domestic Engineer 1jz68u's Avatar
    ok thanks guys will see how i go with getting some rear calipers and rotors. bit gay considering i just put new pads and rotors in them
    oh well better than having a massive accident on the track i guess.
    rep has been spead. thanks guys
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    I'm sure you'll find someone who wants new pads and rotors for their 2/1 setup dude
    Junior Member Grease Monkey TTECelica's Avatar
    Feb 2007
    Just thought id ask, may be a stupid question, but have you greased the slides etc on the rear calipers? do they slide freely and return properly? Alot of imports get moisture in the slides and rust up and bind, and also the extra heat from the racetrack can destroy the grease and it gunks up.
    Im guessing you may have tried, but with the rear end jacked up, can you turn both rear wheels freely and evenly by hand?
    '74 TA 22- 2tg with massive cams!
    "Full carpeting, tinted glass, a tachometer and a Rally-style electric clock."
    havent tried that or regreased them to be honest. Replaced the pads recently and had no trouble moving them. Although by the looks of all the fancy maths above from what i understand of it (i could have totally misunderstood) but i am getting the same, or at least close to, the same braking pressure problem is its over a smaller surface area?? Is that it boys or did i totally miss the mark??
    Also the hunt for rear calipers isnt going well so far, it has only been 1 day but not looking good as the reco'd are not available and new ones quoted price is 620 a side.
    Glenn
    Cheers, Jason
  8. #38
    Where was that quote from!?
  9. #39
    forum sponsor amayama. Though i would try them first. Apparently toyota are still making them also. They are out of 1 side and are making more.
    Glenn
    Cheers, Jason
  10. #40
    toyota NZ cost me somewhere around $1500 shipped for a full set of 4 big brake calipers
  11. #41
    Ahh okay. Haha, mine were a bargain then!
  12. #42
    [email protected]
    just emailed this fella, see if his price comes back different. would be interesting if it does.
    thanks again guys
    Glenn
    Glenn
    Cheers, Jason
  13. #43
    1200, 1500 - something like that?
  14. #44
    the caliper you have now (1pot), has more braking force than the 2 pot. not due to pad area, just due to piston size and disc size.
    pad area helps with heat and consistency and wear etc, but the braking force should not be drastically affected by pad area (in this simple comparison..)
    left side only
    http://page18.auctions.yahoo.co.jp/jp/auction/w54267907
    both sides (this guy usually has higher local shipping costs tho)
    http://page3.auctions.yahoo.co.jp/jp/auction/c263504517
    general search for jza80 in caliper section
    http://auctions.search.yahoo.co.jp/s...ab_ex=commerce
  15. #45
    man i was trying to use the importmonster yahoo search and it was being super gay.
    thanks for the links, is it possible to workout how much the shipping would be to my door?
    and im sure they will sell for more than $40??
    you have the advantage of being able to read japanese dont you?
    it would appear i need to give some more people rep before giving you any more
    Glenn
    Cheers, Jason
    By The Witzl in forum FAQ
  2. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  3. EF/EL XR Falcon Front & rear disc brakes on a Hilux 2WD ??
    By ICELUX in forum Tech and Conversions
    Last Post: 26-08-2011, 11:08 AM
