Results 1 to 6 of 6
Thread: Knock Sensor Voltage
    Oct 2008
    Auckland
    Default Knock Sensor Voltage
    Does anybody know what voltage toyota knock sensors output normally (when knocking/detonation is not occuring). I've heard that its a 0-5v sensor that averages about 2.5v but im not sure if that's true or not, if you know or have any theories please speak up!
    Default Re: Knock Sensor Voltage
    Not much, but some Toyota specific info.
    38 Sensors#8 - Knock Sensors with questions.pdf file size 55KB
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2008
    Auckland
    cheers that helps me understand how knock sensors work a bit better. I just need to know what voltage or voltage range they output so I can bypass it.
    Bypass it?
    piezo output is usually filtered such that only vltage spikes associated with knock make it thru the filter, and trigger a signal in the ECU (afaik?)
    so during normal running there is no signal...
    i am not sure if the ECU checks for resistance/impedance/whatver of the sensor to see if it is still there or not, but a good start would be to disconnect it and see what happens
    or, connect knock sensor and not connect it to the engine.... (may possibly need to earth the casing?)
  1. Knock Sensor CEL code
    By greywolf in forum Tech and Conversions
    Last Post: 26-04-2009, 07:15 PM
  2. Sub 10$ knock detector. (3SGTE and maybe others?)
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 22-01-2009, 08:58 PM
  3. Messing with Knock sensors
    By Drifty Midship in forum Tech and Conversions
    Last Post: 23-09-2008, 06:38 PM
  4. Error code 52 - Knock Sensor Signal.. 1JZ-GTE ....need help
    Last Post: 14-02-2006, 09:15 AM
  5. 1jz knock sensor
    Last Post: 07-12-2005, 04:42 PM
