Results 1 to 4 of 4
Thread: Knock Sensor CEL code
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Default Knock Sensor CEL code
    So I'm looking at picking up an 3S-GE powered MR2, couple issues with it.
    One : Worn 2nd syncros, not a big concern.
    Two : Knock sensor has thrown a CEL code. Now from what I've read this is due to the knock sensor failing. It had failed previously and the owner installed a 2nd hand one from Road and Track in Brisbane. He says that the original was only 1 wire and the 2nd hand one is a 2 wire job. Does this sound right to anyone ?
    He believes that it could be either his bodge wiring job to get the sensor working or the sensor crapping itself that threw the CEL code. From what I've read, the CEL will only display in the case of a failed knock sensor, not in the presence of knock. Is this also true ?
    Lastly, should I take a new knock sensor with me and install before driving it home (4000km trip), or can I make it back and install the knock sensor on returing home ?
    New Zealand
    Default Re: Knock Sensor CEL code
    no that doesnt sound right at all. sounds like the stock one earthed throufh the engine (which im not sure is correct)
    knock sensors are somewhat specific. you cant use any sensor off just anything.
    light will show due to faulty knock sensor. not due to detection of knock.
    you will be able to drive it with out the sensor, it will just pull all the timing and be gutless.
    please, no more PMs!
    I haven't seen a two wire knock sensor.... all the ones I have seen have been 1 wire.
    38 Sensors#8 - Knock Sensors with questions.pdf file size 55KB
    e.g.
    89615-20060 eBay 1 pin
    Wilbo's JZA80
    Wilbo's JZZ12
    Nsw
    Thanks for the links Wilbo666, I'll check them out. I'll get the correct spec knock sensor and wire it up before doing the trip I'm thinking.
  1. AE92 - ECU code 52
    By LeeRoy in forum Tech and Conversions
    Last Post: 08-01-2010, 11:06 AM
  2. Mysterious 1jz problem - ECU code 12
    By cybersimon in forum Tech and Conversions
    Last Post: 08-03-2009, 04:32 PM
  3. Sub 10$ knock detector. (3SGTE and maybe others?)
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 22-01-2009, 09:58 PM
  4. Messing with Knock sensors
    By Drifty Midship in forum Tech and Conversions
    Last Post: 23-09-2008, 07:38 PM
  5. Error code 52 - Knock Sensor Signal.. 1JZ-GTE ....need help
    Last Post: 14-02-2006, 10:15 AM
