Results 16 to 27 of 27
Thread: 3sgte 4th generation (caldina GT-T) Modifications to 300whp?
    wa
    Default Re: 3sgte 4th generation (caldina GT-T) Modifications to 300whp?
    WTA is generally better due to shorter piping and less pressure drop, but possibly more expensive when you add cost of water pump, lines and electronics(dependant on wether you can do it yourself or not etc)
    IMHO a FMIC of that size is overkill for the stock turbo and you'd want inlets of 2.5" max, smaller prob be better
    Feb 2010
    San Pedro
    so if 2.5" is max. then it would probably be ideal to have 2" inlet/outlet diameter?
    Tasmania
    I thought we agreed the stock turbo wont push 300 whp (unless highflowed)
    ideally with a fmic you would have inlet the size of you turbo outlet (so 2" in your case) and the intercooler outlet the same size as your piping and throttle (which ideally should be the same too)
    but we dont live in an ideal world so 600x300x76 is the most common (and cheapest) core.
    skyline GTR cores are very good and reasonably priced generally
    1973 TA22
    Since when are 3sgte injectors 540cc? I thought 7m-gte ones were the biggest stock toyota injectors you could get?
    Also, don't worry about the fuel rail, upgrading that will do fuck all, save your money and get a bigger turbo
    Facebook | LinkedIn
    wa
    since the gen3.....
    gen1 3sgte are 440 topfeed same as the 7m's,
    gen2 are 440 side feed
    gen3 are 540 side feed.
    i presume the gen4 would be 540 at least as they made the most HP from factory.
    the gen2 rail is restrictive and many bore them out. the gen3 rails are normally ok for most. and i'd say the gen4 rail is the same
    Tasmania
    ^^speaks the truth^^
    gen2 rails have known issues...issues that were fixed for the gen3
    additional to that the US jza80 2jz-gte had 550cc squirters
    1973 TA22
    Gen4 are 540cc, but top feed and high impedance
    If in doubt power out
    hrm....
    Top feed high impedence would be handy.
    But I'm tipping hens teeth are easier to find?
    Facebook | LinkedIn
    Nope you can buy them new still, should get the part no. and price through amayama. Used would be hard as I doubt that many people have upgraded them to something else yet.
    http://www.rhdjapan.com/toyota-oem-5...-54144?nflag=1
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Quote Originally Posted by stradlater View Post
    I have 2JZ ADM injectors on my 1JZ which are 550cc.
    EDIT - Ah I didn't realise there was a page 2 with my same answer... :S
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Feb 2010
    San Pedro
    how about a CT-26 Turbo from a 86-93 toyota supra?
    heard these budget turbo mods
    http://www.alltrac.net/tuning/turbo.html
    wa
    as your turbo housing is one piece cast into the manifold i don't think it'd be worth the hassle trying to get it to fit. this is more of an upgrade for gen1 3sgte's as they are single entry and the turbo bolts on with little to no mods.
    so have fitted them to gen2's as well some retained the twin entry exhaust housing, other used the single entry housing and "blended" the ports.
    i'd just start with the simple ungrades first and see if you pleased with the results, if not then save for a new manifold/turbo/dump combination
  1. 3sgte (4th gen) basic to advance modifications?
    By st.celica in forum Tech and Conversions
    Last Post: 24-06-2010, 09:45 AM
  2. 98 Caldina 3SGTE timing belt
    By wipava_454 in forum Tech and Conversions
    Last Post: 07-05-2009, 03:46 PM
  3. Caldina 3SGTE wiring help
    By Jaffa in forum Tech and Conversions
    Last Post: 24-03-2008, 08:35 PM
  4. Different Generation 3SGTE Interchangable parts
    By Howieau in forum Tech and Conversions
    Last Post: 29-07-2007, 04:08 PM
