Results 1 to 8 of 8
Thread: 1975 Series 1 RT104 Corona - T Series LSD?
    Toymods Club Member 1st year Apprentice
    Apr 2010
    Default 1975 Series 1 RT104 Corona - T Series LSD?
    Hi everyone!
    I bought a standard 1975 RT104 Corona (series 1). I then put an 18RG in it. After about 2 weeks the diff started to whine (looks like it doesn't enjoy having twice the power lol).
    I did some research using a database on here to find out that series 1 RT104 supposedly came with the T-series diff (T292) and a 4.1:1 ratio.
    My plans are to get the diff rebuilt and while it's apart get an LSD put in.
    Has anybody put an LSD in an RT104 before?
    Can I use the same T-series LSD's that they use in their AE86s with their T-series?
    Thanks alot,
    Stephen
    Aug 2009
    Default Re: 1975 Series 1 RT104 Corona - T Series LSD?
    Hi. I just recently purchased a JDM T series LSD through eBay, which was from a Jap importer in USA, which was posted direct from Japan.
    The pre 1985 AE86 had the smaller axles, called Zenki axles, later had larger and more splines, called Kouki axles. You will need to know size and number of splines on your axles first, unless another member can tell you.
    The LSD cost me $360 AU including post.
    If you are interested I will pm you sellers details.
    I am not connected to seller other than being a happy customer
    Regards
    Tony
    Apr 2010
    Quote Originally Posted by ToyTA22 View Post
    Regards
    Tony
    Thanks for the info
    That price seems pretty good too.
    I wonder if my diff is the same as the RA23 and RA28?
    What LSD do they use?
    Anyone else got some more info?
    Apr 2010
    Surely somebody has put an LSD into a series one RT104 or knows the exact details of the diff?
    Junior Member Too Much Toyota GUN METAL's Avatar
    sounds like a geat idea, get onto this guy >> http://www.toymods.org.au/forums/member.php?u=5154
    or this guy >>> http://www.toymods.org.au/forums/member.php?u=93
    you might also be interested ibn this >> http://www.toymods.org.au/forums/showthread.php?t=61110
    MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
    AW11s always welcome in my driveway !
    Apr 2010
    Smile Re: 1975 Series 1 RT104 Corona - T Series LSD?
    Quote Originally Posted by GUN METAL View Post
    Thanks man. I'm definately interested in the RT104 GT
    I'll try shooting a PM or two.
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by iTz InSaNiTy View Post
    Its an F series
    I have a 3.9 4 spider slippery if you want to convert it.
    Here is rear end complete with the rear discs it should have had in production.
    And the Factory rear stab bar.
    The trick is to make a spring steel ciclip to act as a spacer so you can use your own Corona bearing retainer plates and you dont have to split the bearings off to fit the Avanti retainer plate.
    QED
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    Apr 2010
    Hi RT104GT,
    First of all I would like to say your car is awesome!
    Also thanks for seeing this thread and commenting.
    As far as I can work out from my reading of different threads and databases my diff is a
    T292 diff with a 4.1:1 ratio.
    From everything I have gathered it seems the F series diff (4.11:1 ratio) that you are talking about only came in the RT104 GT and not the standard RT104 that I have.
    I will try and get some pictures of my diff uploaded soon.
    Thanks again,
    Stephen
    Quote Originally Posted by RT104GT View Post
    Its an F series
    QED
  1. 1JZ-GTE into 77 corona (RT104?)
    By Godzilladat in forum Tech and Conversions
    Last Post: 17-01-2012, 09:51 AM
  2. RT104 corona diff fit ST141 corona's?
    By cranker in forum Tech and Conversions
    Last Post: 26-11-2006, 12:07 AM
  3. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 06:14 PM
