Yeah. Who needs VVT when you are always at Max Torque...
it will be interesting to see what CVT transmissions becoming increasingly available will do to the future power delivery of engines..
well on a completely different thought regarding that... imagine only having to tune your engine for the best power and economy in a few different rev ranges.. like the most efficient RPM for cruising, and max hp for acceleration..
Lots of good data...but you kinda mixed up the summary. HP is a mathematical term, but Torque is totally useless when quoted all by itself. Hell, a giant CAT diesel makes killer torque, should I be scared of lining one up? The point is that HP exists as a measurement because you need to be able to apply the torque to the application. If you're trying to do 100km/h, and your engine redlines at 5k, no matter how much torque it's got, it's going to need to be geared correctly, thus removing the torque advantage over a smaller motor which revs harder. My car makes 4000NMatw. Hence why we have: HPatw instead of NMatw. Because that'd just be a game of gearing.
To sum up: As said before, it's all about the torque curve, and the gearing. That being said, I'd put my money on the smaller, revvier motor, as long as it could stay in the RPM range, because it likely has much lower rotating mass.
RM.
Originally Posted by The Last Streetfighter
Yeah, but there's more friction as you spin faster.
Aye, it's a conundrum.
Agreed, I didn't think about that. Although you've got half as many pistons thrashing around...
RM.
This is true, but it's still likely to have less friction than the bigger engine at lower RPM. I'm not saying either way, but rather pointing that out.
I just see it like this - if you have a heavy car then you should probably look at a bigger lower revving more torque engine. Lighter cars can get away with high revving lower torque engines... but high torque engines are good fun anyway.![]()
Hydra
JZA61 Celica XX
ahem..... what do the Super trucks run on a 1/4??? when not speed limited to 160, they do 12 sec 1/4Originally Posted by mullett
.. not bad for big truck engines
Hahaha...I'll give you that. Wiseguy...
But, same scenario...they make 1000+HPI wish I had 1000+HP. But then, I DON'T wish my car weight 6tonnes...
RM.
And the R-4360 generated 840ft-lb of torque at 1,000rpm. At max revs of 3,000rpm it generated 7,506ft-lb. The output shaft ran at 1,125rpm when the engine was running at 3,000rpm, and generated over 20,000ft-lb of torque.
Still, it is a big engine - 28 cylinders with a bore/stroke of 5.75inches/6.00inches - with a total of 4,360 cu inches (71.5 litres) , with a compression ratio of 6.7:1.
The carbie was a single four-barrel unit with a throat diameter of 20 inches.
Check out the lovely cut-away pic to see its guts...
Marvellous stuff. I love big piston engines!!!![]()
without even opening that link, I'm gonna bet it's that warehouse-sized engine, with a guy standing inside one of the cylinders
Pfftt.... diesel!!!
However, it is mighty big and I lvoe the size of the crank.!!!
You forced my hand now to show the ultimate piston engine.... a thread stopper!!!
Game over. End thread!![]()
nyuk nyuk nyuk
seeyuzz
river
Here's a chassis for it to power
