Results 16 to 25 of 25
Thread: 5e-fhe pistons... Turbo friendly?
    wanker Backyard Mechanic MS-75's Avatar
    Default Re: 5e-fhe pistons... Turbo friendly?
    If you have a side elevation picture of the pistons I can tell you how strong they are likely to be.
    [email protected], WSID, COMPAK ATTAK, MAY 2006
    Chiba
    Quote Originally Posted by abently View Post
    Now that makes sense with everything I've seen. Thanks!
    I assume you are talking about CP 5efe Forged pistons?
    The same is true for both stock and aftermarket pistons. Except for the 5E-FHE pistons. I am yet to find an aftermarket one of those.
    Jun 2007
    Quote Originally Posted by MS-75 View Post
    Piston on the left.
    1st Ring land is a reasonable distance away from the crown.
    If you want a better side elevation pic, let me know and I'll try to find one.
    Jun 2007
    Actually, here is a better pic...
    Taken from > http://www.tercelreference.com/terce...rod_piston.jpg
    You should also ask on here: http://www.austarletclub.com/forums
    A lot of knowledgeable guys on there with E series experience.
    Crown thickness and ringlands look really good, however those valve reliefs aren't so good. Those are likely to be the weak points if you get it into a lean condition. I'd say the margin may be a little slim for the HP you're chasing.
    For that HP, I'd assume you are looking at decent rods as well? Those stock rods look terrible - they'll banana no question at all.
    The stock 5E-HFE rods are stronger than the 4E-FTE rods which are good for a decent amount of power.
    Chiba
    A better pic I just took of a 5E-FHE piston.
    Maybe, but not 100+hp per rod.
    No, but remember it is a 1.5L engine.
    The HFE rods can get decent numbers for a engine of that capacity.
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  2. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 08:58 PM
