Rickq, have you considered simply fitting 8.9:1 gze pistons and a smallish T20 (or similar) turbo to your current engine?
You're likely to get similar response to the SC without the headaches of modding basically everything. You've also got a far larger range of turbos than you would SC's.
With the T2X series manifold, you can try everything from the T20 to the T28, and move your power band till you like it most.
As for implementation, it's remarkably simple once you've done the internals.
If you havent got an aftermarket ecu, you'd need to acqire a MAP sensed GZE ECU and appropriate sensors and wire it all in etc.
But you'd have to do that if you started with a GZE base anyhow.
With the GZE base, you have to find a spot for the SC, redo the inlet tract almost from scratch (due to the north south conversion)
It's a big job, and without other mods, you're likely to achieve a mere 100kw @ the treads.
In the future, once you've adapted to the power, and become bored of it, you're quite likely to try find an SC14, and deal with THAT headache, or go turbo anyhow.
It's up to you, but after watching a doco on jet engines and the huge fan efficiency improvements they've made in the last 5 years, I'm definitely thinking turbo's have to have come a long way too.
