Results 1 to 11 of 11
Thread: GA70 loom questions.
    Excited Member Grease Monkey thomasbl's Avatar
    vic
    Default GA70 loom questions.
    Hi guys. I am currently working on a 1ggte/ ra28 conversion.
    Trying to get my head around the loom at the moment and have a few simple questions.
    A black unit, labelled 'retractor unit', what does it do?
    ECU main relay. Where will i find it?
    Anyone who has done this before, did you use the fusebox form the 1g?
    Any other tips, hints or advice would be greatly appreciated.
    Thanks
    Default Re: GA70 loom questions.
    Is it an early one or a later one? Yellow plugs or grey??
    Retractor unit sounds like something for the headlights, not the engine.
    vic
    Its a late model, gen 3 engine out of a late 88 model i believe.
    My assumption was that it was for headlights, but i thought i would get some confirmation. thanks
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Have you seen the 1GGTE ECU connector pdf files? Do a quick search on the old forums and you should find plenty of info.
    Hope this helped ya out.
    vic
    Thanks d-master. I have copies of the 1G-gte pin-outs etc from the old toymads forums. I actually feel like i have exhausted all of the online wiring info i can find.
    Most of what is on the old sites shows the engine side of the loom, however, some of the other wiring of the car is ommitted. Thanks anyway, if anyone could clarify just what the retractor unit is for it would be greatly appreciated. tom
    Retractor unit has nothing to do with the engine.
    Sorry, I should've clarified. I'm fairly sure the retractor unit is for the headlights, but it definetly has nothing to do with the engine.
    vic
    Thanks guys. consider the retractor unit gone....
    If ya get stuck, just give us a holler. I've just redone a Gen3 1GGTE loom on my car, so it's all kinda fresh.
    vic
    Thanks mate, really appreciate that. I think i am going ok at the moment, as the new school semester has started, i am able to spend less time working on cars and more at work so progress is slowing a little but ill let you know how i go. Think i have the fuel pump and circuit opening relay stuff sorted, still not sure bout the ECU main relay though? Is this the round relay in the fuse box labellled 'main'? Also unsure about which wires to use to run power to the fuel pump? There are some heavy gauge ones in the section of the loom which ran down the sill to the rear of the car? Could these be the ticket? thanks
    Yep, the main relay is the one in the fuse box that says MAIN. Just run your own wires, cant hurt to have something fresh given the age of the car.
  1. AE86 JDM loom plug identity
    By parrot in forum Tech and Conversions
    Last Post: 27-12-2005, 09:58 AM
  2. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 07:10 AM
