Results 16 to 18 of 18
Thread: Base Fuel Map - 4age 16v big port
    Default Re: Base Fuel Map - 4age 16v big port
    Probably not much help but this is the last 4AGE I ran a few years ago.
    Still wasn't the final tune though.
    Small port head, Motec M4 ECU, 4AGZE injectors, ~290° cams.
    www.billzilla.org
    Toymods founding member #3
    Quote Originally Posted by 3jcelica View Post
    Yeah,
    Megasquirt stuff is going to be no good as it is all in Volumetric efficiency, the haltech you have needs injector open time which is more dependent on injector characteristics
    Roger
    Hi Roger.
    MS works out "required fuel" for "100% VE", which in the above case was 14.4ms per revolution.
    then you multiply the VE in the table by 14.4ms to get the numbr of ms.
    ie, 40VE gives 0.4 x 14.4 = 5.76ms
    not sure it could be simpler
    was the haltech map for stock injectors? or bigger ones?
    oregon
    Quote Originally Posted by irishtwincam View Post
    OST: Is it the fuel map a representation of the difference in VE vs factory fuel map?
  1. can a standard big port 4age map sensor read boost?
    By kewp in forum Tech and Conversions
    Last Post: 29-08-2007, 04:08 PM
  2. Replies: 1
