Results 1 to 13 of 13
Thread: 22r hilux engine problem - rebuild?
    Default 22r hilux engine problem - rebuild?
    HI All.
    So I went and bought myself a 1989 22r dual cab hilux 2wd.
    Turned out to be a bit of a lemon, however it has a good gearbox with a brand new clutch and new radiator and hoses etc. The body is also in really good condition, no rust dents or scratches to be seen.
    So my problem is the motor, and my question is:
    How much would it cost to get a mechanic to rebuild the motor? I'm just after a ball park figure so that when i go speak to my mechanic I know what im in for.
    Cheers for any help you can give me.
    Adrian
    Banned Grease Monkey toyboyracer's Avatar
    Question Re: 22r hilux proplem
    Obvious Q, why do you think it needs a rebuild ??
    Default Re: 22r hilux engine problem - rebuild?
    It doesn't seem to run smoothly, it uses a heap more petrol than what others do and it has a load rattly when the engine is under any sort of load which ive been told is the timing chain.
    *loud rattle
    Wink Re: 22r hilux engine problem - rebuild?
    Rattling...
    Timing - lols
    thanks for your help...
    Thumbs up Re: 22r hilux engine problem - rebuild?
    Also called "pinging" can be called rattling caused by incorrect timing or low octane fuel
    Tallahassee, FL USofA
    Quote Originally Posted by goodwood View Post
    ... it has a load rattly when the engine is under any sort of load which ive been told is the timing chain.
    What's the compression?
    The timing chain doesn't care whether the engine is under a load or not, redline in 3rd gear going up a mountain or coasting down a mountain in 1st gear at redline, it is only affected by the crank's RPM not the load on the engine.
    Pinging, pinking, spark knock, detonation, also names for the sound like marbles in a tin can or a small bell.
    Arrow Re: 22r hilux engine problem - rebuild?
    Using a lot of petrol could just be the mixture being too rich
    Clockwise is leaner
    BASIC setup as follows...
    Get engine to operating temp
    Screw in the mixture screw GENTLY until the engine starts to stutter
    Back it off anti clockwise until it smooths out
    Extra 1/4 turn and done
    Get your mechanic to do a basic service 1st & tune up - May surprise you with +++KWs
    Sounds good, I'll give that a go. The pinging only happens when Im in gear in the middle of the rev range, At low or high revs it runs ok. If the car is just sitting there in neutral it doesnt make the pinging noise anywhere in the rev range.
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    These engines also do usually have a rattle, you could try also doing a valve clearance adjustment back up to the proper specs. Which may help the rattle. Even after doing this my old engine still used to rattle a little.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Timing too - doh (slaps forehead)
    10 to 12 degrees advance general setting
    great thanks for your help guys. I'll let you know how i get on.
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 07:21 AM
  2. TA22 problem! low engine!
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 04-02-2008, 11:48 AM
  3. MA70 --> JZA70 Conversion
  4. 1ggte Engine Problem
    By ToNkA in forum Tech and Conversions
    Last Post: 26-12-2005, 10:27 AM
