Results 31 to 45 of 47
Thread: Ke70, missfireing only when engine warms up
    Tallahassee, FL USofA
    Default Re: Ke70, missfireing only when engine warms up
    Quote Originally Posted by Scoobzd View Post
    Done right = no rattle . Done wrong = valves not closing.
    When the valve face wears and/or the seat recedes, the the lash closes up, when the lobe & cam & bearings & lifter/follower/tappet & pushrod & valve stem tip & rocker bush and its tips wear, or everything get hot, THEN the lash opens up.
    What's Dad's warranty?
    Banned Backyard Mechanic Scoobzd's Avatar
    Apr 2007
    Thumbs up Re: Ke70, missfireing only when engine warms up
    And now everyones enlightened as to why u dont have a zero tolerance !
    Cheers for that allencr
    20,000ks or 200 beers - Customers choice !
    from Dad
    I didn't think anyone asked about zero tolerance. If you set the valves clearance in accordance to the engine manual, you will be fine.
    What I was asking about was the reference, in your earlier post, where you set the tolerance with "an everso slight amount of clearance because the valves are seating themselves with every closed action".
    The factory manuals show the clearance that needs to be set. Do you set the valves "everso" more than the factory specifications?
    seeyuzz
    river
    Banned Grease Monkey toyboyracer's Avatar
    Red face Re: Ke70, missfireing only when engine warms up
    Ok, Gordon here - Hiya everyone - Waving
    After dicking around with cars since ummm... 1982 this is hard to explain - But I'll try
    When using feeler guages a FIRM / SNUG / TIGHT feeling is the norm
    When setting the valves a loose but not sloppy assed feeling is required - Makes sense ??
    Guessing maybe .003 thou' is what I aim for UNDER the fact specs
    "In time too you too my learn the ways of the Force my young Paduwan"
    Gordon,
    If the feeler guage is sloppy when set to the correct feeler thickness for the setting you are trying to acheive, then the gap is to big and your doing it wrong.
    Adding additional clearance ABOVE the factory spec will only result in reduced valve lift and hence reduced power, that sounds like an awesome idea
    Adding .003 thou can also be quite a large percentage increase.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Arrrghhhh.... Typing my point is so hard (grrrrrr )
    As I tried to state, would you rather your valves be fully seated or NOT ?
    If not then your compression will suffer = Waaaaay less power
    In a perfect World we all would be running solid lifters = perfect seat and opening
    (race motor apps) and this discussion would be a moot one indeed !
    The feeler guage is a "feel" of how you use the tool
    A really FIRM feel is how I set plugs = Damn tight
    With valve clearances = Not so tight
    As valves are ^ and are FOREVER seating and embedding themselves I go for a (sloppy) LOL
    guagement to allow for this.
    Making sense yet ?
    Not trying to start a fight but I know where I'm coming from here
    Lillehammer
    Setting the valve clearance gap isnt really very hard, set it too tight and u wont get the feeler gauge out, set it too lose and u can slide in a 0.40 instead of a 0.30 wich is the factory specs for example.
    I dont wanna drive around with a engine that rattles like a rattlesnake on meth, so i rather set it at perfect factory gap than sloppy, or too tight. In my opinon its not a easy thing to set that gaps too small/tight if u use a feeler gauge, like i said, u tighten it up and u wont even be able to pull the feelergauge out, and if u get it out, u sure as heck wont be able to slide it back in.
    Its like a breaker point, if its 0.45, u dont want 0.50 or 0.40, u want it at 0.45, its nothing in between. (unless its a specific reason u want it higher or lower of course)
    Maybe im just picky about setting the gaps here and there, but thats my way i guess
  8. #38
    rattlesnake on meth
    would be a Mazda 929 motor !
    I think you get where I'm coming from Mark
    (God I hope someone does !)
  9. #39
    Lillehammer
    Yes of course, its better to have too much clearance than not enough.
    some years back a friend of mine set the clearances too small on a opel rekord 2.0L, vauxhall/holden or whatever u call it down in australia. After just a couple of days the crackshaft rod made a hole in the block the size of a fist . It was probably more things than just the valve clearance that was wrong with the engine tho, but u could hear the compression flowing thru the tappet cover and everywhere when the engine was running.
    But then again, dont go for sloppy, go for perfect
  10. #40
    Gordon, I understand where you're coming from, but I don't get why you set the clearance more than factory spec - even if it's just a "fraction". The valves "seating and embedding themselves" shouldn't be an issue.
    The exact factory specs are perfect for the engine and that's what the valves should be set too.
    However, if you find setting them slightly more works for you and the engines, then that's cool.
    seeyuzz
    river
  11. #41
    Lillehammer
    Hi again
    I did the compression test today, and it seems very good. Every cylinder had compression on 11.5 bars. Kinda confusing tho since the manual says it should have 9 ?
    I also set them timing perfectly and the car got a lot more power, even at higher rpms, but valve floating still happens at 6300rpms, a lil low isnt it?
    Will adjust the carb later today and hopefully the engine is good to go.
  12. #42
    Apr 2007
    I'll get a friend who works here a Toyota to see what sum shiny new valve springs will cost !
    If cheap enough will post them over to you ASAP !
  13. #43
    Lillehammer
    Hi
    Thanks a lot for the offer, but i just got off the phone with my local toyota dealer and they said i could get the new ones for 30 bucks for a set of 8, just to clear out their inventory for old parts. I also got a clutch release bearing and some other stuff for like half the regular price
    Thanks a lot for offering tho, would have been very usefull, i appriciate ur help
  14. #44
    Apr 2007
    Wink Re: Ke70, missfireing only when engine warms up
    Excellent score there !
    The buzz box will now redline @ 6700rpm
  15. #45
    Lillehammer
    Yet another question
    Wich way do i screw the mixture screw to make it run leaner? is it in or out? im using a vacuum meter to adjust the carb, but its a pretty big area where the vacuum is on top, and i want it to run as lean as possible, so is leaner screwing it out or in? i never remember wich way it is.
    Thanks again for ur help
  1. MA70 --> JZA70 Conversion
  2. my masochist engine swap... 3S to RWD
    By Roman in forum Engine & Driveline Conversions
    Last Post: 10-04-2007, 10:22 PM
