Sucking air through through the inlet gasket would upset your mixture and ALSO upset its revving and power.
Might need to redo the mixture after replacing the gasket.
Next step is to take off all the ground/earth wires/straps, sand where they contact as well as their ends
and reattach with star washers.
Is the engine set at 10 - 12 degrees advance ?
If say it's on 0 - 5 it would be a lot less responsive than your previous motors.
Before just ripping the head off, do a compression test - Always do that before so that you have a base line
to compare with![]()
