Results 1 to 12 of 12
Thread: Getting an Locost to engineered?
    Perth, WA
    Default Getting an Locost to engineered?
    Hi guys,
    Just wondering how hard it is to get a diy build locost 7 engineered and get thru the pit? what are the procedures?
    has any one attempted and get a rego successfully in WA? or it is impossible to get a rego for locost 7?
    i saw few on the street of Perth, they might not be DIY version, could be a kit car ot real caterham, I'm not sure...
    perth
    Default Re: Getting an Locost to engineered?
    call southam engineering in williton on whyalla (sp) street.
    terry southam is his name, this is his thing....
    ill try find his card and give you his details.
    Nice..... Grease Monkey Rex_Kelway's Avatar
    First stop should be the WA transport authority.
    When Rex began His Locost He went to Transport SA. They Had a little ICV booklet and some application forms.
    After lodging the forms about vehicle spec, Transport SA handed down a 'statement of requirements' which lists everything they want to see in terms of engineering reports and testing. They also included a list or approved engineers and procedures to do so.
    WA should be similar...
    In the end Rex ditched the idea of registration in favour of competition only...
    Rex Kelway Sucks - Fabrication thread
    Rex Kelway - ABN: 41 267 379 001
    Fabrication, Manifolds and CAMS spec Roll-cages in SA...
    perth
    hahah getting info from transport ha ha ha.
    those guys are only good to get angry at.
    but yes rex is correct, normaly you fill forms (about your build and mods) send it to transport, they send it back saying yay or nay if its a yay then you go to an engineer and he signs it off, then you send the papers back to transport and they okay it and send it back, then you go for inspection.
    if you ring terry he can tell you what you should/can do, so when you fill the papers out you can do it without any guess work and less time wasted.
    Perth, WA
    so let say it gets a nay from transport WA. if i built it for trackdays/hill climb event, how would i know what are those tech inspector in the event is looking for?
    perth
    i dont do any cams racing so i dont know, but at the run what ya brung events like drags and track days they just check for obvious faults and have simple safety guidelines, if its a cams event you would need to get cages and welding signed off and cams approved.
    Perth, WA
    ok cool... that should keep me motivated... cheers
    perth
    0417 811 044
    unit10 /14 whyalla st. willeton
    Junior Member Grease Monkey rick q's Avatar
    Get onto OzClubbies [ http://www.oz-clubbies.com/forums/ ], join up and search. There are plenty of people over in WA doing it.
    Cheers ..... Rick Jones
    Fraser Clubman
    Perth, WA
    thanks for the tips....
  1. 20 vavle in AE92 need to be engineered
    By SXI20V in forum Tech and Conversions
    Last Post: 28-06-2006, 03:56 PM
