ok guys, as said above, you shouldn really mix the 2 types of paint but it is possible when done right. you should NEVER put 2pak over acrylic, as also said above, acrylic cures by losing and evapourating solvents, ie, thinners. this process can take months, even upto a yr, putting 2pak clear over the top will trap these solvents in as it sets hard, when all the solvent are trapped they keep trying to get out and it will eventually lead to crows feet and humidity blister looking paint, therfore the need to strip it all and paint it again!!
you can put acrylic over 2pak witout any probs but NEVER go the other way!!
there is absolutely nothing wrong wit acrylic paint ecxept the extra work to get it looking good and of course the shrink back that occurs. as one of the guys said above, put plenty of clear on and face it off wit 1500-2000 wet to get the peel off, a good way to do this is to start rubbin, usin heaps of water and put some car wash detergent in the water to help stop the paper from loading up, a nice soft flexy rub pad should also be used, if you are not sure how nuch clear you have taken off simply dry the area wit a old chamois and you will see little shiny dimples in the paint, if a fully smooth and peel-les look is wat you want keep repeating this process until the area is totaly dull before you buff it, if you are buffing under flouro lights or in a dim area dont be too concerned bout and fine scratches in the paint after you have buffed it, this will always occur using acrylic paint systems, you wont be able to see them in daylight!!
when painting wit acrylic NEVER try to get a glossy and shiny finish off the gun, as you will be dissapointed, when painting the clear, start wit the 1st coat mixed as reccomended, then next coat add 15% more thinners, then 15%more wit next coat until you end up wit 1part clear to around 3parts thinners, this wit using a little more air pressure than reccomended will gice you less peel to face off prior to buffing, saving you a few hrs and also your arm from dropping off!!
i would confront the guy at the paint shop and ask him why he told you that you could use 2pak clear over your acrylic as it would have stuffed your job, ask to see the manager and tell him/her as it could have cost you alot of money and time if you had of taken his advice
a good clear to use is the 1 some1 said above, protec have great products and from memory its around $70 for 4ltrs
all the best and if you have already finished your job then i hope my advice will help some1 else and CLEAR up a few thigs that was said above
krem
So i'm left with a half buffed finish because i dont wanna buff through to the undercoat. That is the only thing i would change about the way i did that car.
