2pak is EASIER to paint than acrylic, because A: it is less finiky when applying ie: less likely to fisheye, bloom, or separate the metalics etc, and B: because you use less, ie 4 coats of 2k coulor = 10 coats of acrylic and you can blow the 2k coulor on quite hard.
All metalics require a clear as there is no gloss in the base, also allows for the addition of pearls and tricky preeti stuff before sealing, any solid coulor usually has the gloss in it already, ie: white, red, black, solid blues and greens etc...
acrylics, enamels, urethanes etc all go off with evap. of solvents and a reaction with thinners, thats why iy doesen't keep once thinners has been mixed in.
Hardeners some isocyanate some not can be used with nearly all paints, though specific in thier application, ie enamels have their own type as do urathanes etc...
Once this hardener has been added it is now called a 2 pack. the hardener goes in the clear or the solid gloss coulor.
The reason they react is because they are not equal in their compisiton and compatibility and it usually cracks after getting really hot or cold. My bonnet has craked in heat circles because i used a different brand of hardener to coulor, looks kinda cool
