Results 1 to 12 of 12
Thread: 1jz/2jz custom fuel rails suit standard sidefeed injectors
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default 1jz/2jz custom fuel rails suit standard sidefeed injectors
    as in title, are 1jz/2jz rails interchange able?
    also can people post up pics of how configure the twin feed fuel rail ( each end ).. aka
    aftermarket fuel regulator > hose > y fitting > 2 hoses to fuel rail?
    or
    aftermarket fuel regulator > hose > rail
    regulator return > rail
    rail > return hose ?
    cheers!
    87' z20 Soarer - 1jz Gt35r -
    Default Re: 1jz/2jz custom fuel rails suit standard sidefeed injectors
    Quote Originally Posted by forey View Post
    Nope
    You need to go
    Pump -> Filter -> 2 Feeds to Rail -> Rail -> One outlet to Fuel Pressure Regulator back to tank.
    You can also have two fuel filters, two pumps etc and then go to the rail, but regardless you need two feeds to the rail. The fuel pressure regulator comes off the rail and goes back to the tank. The FPR isn't before the rail
    It also depends on if you are talking about 1JZGTE or 2JZGTE.
    This is my dual feed rail for 2JZGTE.
    I drilled and tapped the 'spare' end (Left looking at the pic). And I also tapped where the stock fuel pressure regulator goes and ran off to my SARD ragulator.
    Pic
    Wilbo's JZA80
    Wilbo's JZZ12
    TAS
    will be fitting to a 1jz, with sard regulator.
    Well the 1jzgte rail is already tapped both ends, so you really need to weld or drill and tap a fitting into the middle of the rail for the FPR to connect to and then feed from each end I would have thought
    Wilbo's JZA80
    Wilbo's JZZ12
    ^ ^ what he said. dual feeds at the end, 1 FPR in the middle, success
    TAS
    kinda confused, currently i have the FPR mounted to the strut tower with one fuel hose going to the fuel rail and the other back to the tank... hence i must have it FPR before the rail..will check it out and get back to you
    That should be your return line. If there wasn't a line running back to the tank from the FPR then it wouldn't be regulating anything.
    JZ aren't a returnless engine, so there are 2 fuel lines going to the tank, 1 in, 1 out
    Read the below pdf:
    http://www.autoshop101.com/forms/h22.pdf
    From here:
    http://www.autoshop101.com/autoshop15.html
    Might clear up some confusion
    Wilbo's JZA80
    Wilbo's JZZ12
    TAS
    very informative, thanks willbo! + rep for you
    next question: as im not near my car atm. any idea what the fitting thread is either side of the 1j fuel rail so i can buy fittings..
    also for the time being: can i have PUMP > left side fuel rail IN> rail > right side rail OUT > fuel reg > return?. and later on tap a fitting into the middle of the rail.
    currently i have it pump > fuel reg/return > rail ( one end of rail is blocked off ) only. which seems to work fine. although id rather do it properly for tuning etc
    I believe that the thread is M12x1.25.
    Same fitting both ends if I recall.... but if you're trusting my memory you're pretty brave... it's been a few years since I've owned a 1jz
    Why can't you wait until your next near your car to check ?
    The below will work fine, and is how it is setup from factory
    PUMP > one side fuel rail IN> rail > one side rail OUT > fuel reg > return?
    Wilbo's JZA80
    Wilbo's JZZ12
    TAS
    cheers again mate, much appreciated!
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
