why not just get an AE71 clutch cylinder and convert the KE70 pedal box?
its pretty easy to do.
im not sure about adapting a whole different pedal box, but i converted my KE35 to hydraulic using an AE71 clutch cylinder, and it was pretty easy.
im sure this has been covered before but i cant seem to find it... whats the difference between the ae86 and ae71 pedal boxes? as far as i know the ae71 is more of a direct fit into the ke70, but im finding ae86 ones are easier to source. So knowing the differences before hand would be good so I know what im up for! thanks
Signatures must be no more than 5 lines of text at 1024x768. Advertising is not allowed in signatures.
i have heard that there is a spot in the firewall thats the size and correct position for a hydraulic cylinder to be placed.
i have seen pics of this being cut out and the rod put through and connected to the stock ke70 pedal. (ill try to find the pics)
would save converting the entire pedal box, but it may be worth it in the end if it gets to hard.
Originally Posted by The Witzl
yeah, ae71 would be nice but no-one up here seems to have any... plus all the ones at the wreckers seem to have been taken already! ae86 ones on the other hand seem to be everywhere!
86 pedal does not easily fit into a ke70. i have done the conversion, 86 pedal into 81 model automatic ke70.
if you drill holes in the firewall on the flattened of provision for the clutch MC the pedal will not fit. it will foul the steering column bracket.
definately you must fully dissasemble the dash, take out the heater box, and drop the column. then and only then would i suggest trying the make the 86 clutch pedal fit first. get it sitting where it should and then drill the holes for mounting to the firewall/ clutch MC.
you will then have trouble attaching the 86 pedal to the 70. 86s have a column support bar running transversly across under the dash. 70 pedals just bolt to the bulkhead. i had to weld some flat bar to the side of the 86 pedal so that it could reach far enough to drill a hole and bolt it to the column.
this is only my experiance. manual or later model ke70s may be differant.
far out! im there!first thing in the mornin! cheers!
I put a AE86 clutch pedal in my KE70 P/van, no probs with it fouling on anything, plenty of room between it and the steering column, i didnt remove a single thing, besides the old clutch pedal, theres was no way i was gonna remove the dash(saw phrosbyte's efforts) ,
But thats get's me thinking the P/van setup must be slightly different to the sedan's?
Im just a little lostbut ill be fine!
on what plane of existence is it anywhere NEAR possible that an AE71 pedal box is harder to find than an AE86 pedal box.
... it's like saying an AE71 is more valuable and sought after than an AE86.....
Originally Posted by beige_bandit
i would say it might be more manual/auto differances.
we did this, took ae86 pedal box and put it into the KE70 for a 4age conversion.
A big hole and two little holes had to be drilled, and the whole dash had to be removed, my mate did this while i wrestled with the engine, but ill ask him if you need details.
Eldar.O.
Originally Posted by Dimitri
Is anyone here talking about putting a manual where an auto was? i know i'm not
got that pedal box from pick n payless and its all installed now just like i expected it to! was a bit of work but not impossible! ae71's pedal boxs dont seem to come up that often round here (Sydney) - all the wreckers ones are either gone or are auto's... been advertising on all the toyota forums for a few months at least... whereas ae86 were much easier to find (for me anyhow)!
the thread asked about converting a KE70 to hydraulic clutch. ive done such a conversion. i explained the difficulties i had. you mentioned you did the same conversion and didnt have such difficulties, i suggested it may possibly be because my car was orginaly auto.Originally Posted by beige_bandit
^^^^ oh, sorry!
I didnt realise you had an auto, but even eldaro (unless that ke70 was originaly an auto aswell) removed the dash, in phrosbytes conversion write up he also removed the dash!
i still got a feeling there is a difference between the ke70 sedan's and the P/van
