Results 1 to 10 of 10
Thread: Removing Head 18rgeu
    Aug 2008
    Default Removing Head 18rgeu
    Aug 2008
    Default Re: Removing Head 18rgeu
    Prior to removal ensure engine is at top dead centre on NO1 piston and mark cam chain and cam gear position. Undo tensioner on the side of the head. Bend back locking tab on the cam bolt, Cams have a square section on them.Use a 300mm shifter to hold the cams in position. undo the cam gear retaining bolt, remove small locating pin very carefully so as not to drop it in the timing cover. remove cam gears.and support upper timing chain.
    JOBS DONE
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Aug 2008
    There is a nut/stud around the front that goes through the timing chain cover.
    Aug 2008
    Well that looks like a good enough excuse for some 92mm forged pistons and a little head work.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Aug 2008
    Thread locked.
    Pls use the existing 18R-G threads for 18R-G questions & answers.
    seeyuzz
    river
    PS: Re-opened, due to popular demand.... but I'd still prefer the existing threads are used.
    Aug 2008
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. Building up a mean F head
    Last Post: 02-01-2009, 01:10 PM
  3. Removing / Inspecting valve springs without removing the head - is it possible?
    Last Post: 16-06-2006, 01:58 AM
  4. Removing cam gear
    By Ender in forum Tech and Conversions
    Last Post: 09-03-2006, 10:05 PM
