Results 1 to 3 of 3
Thread: Want to start car!! Autronic SMC..LC-1..3TGTE.. Trigger pulse offset = Huh?
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Want to start car!! Autronic SMC..LC-1..3TGTE.. Trigger pulse offset = Huh?
    Ok how the hell do I setup the trigger pulse offset and all that jazz?
    I'm using a 24+1
    1 - When I line the cyl 1 trigger pulse with the VR sensor, the timing mark on the crank is roughly about 60btdc is this right?
    2 - When I try and start the motor, im getting roughly 21 to 35% sync is this a good thing?
    3 - How do I improve cyl sync with the two VR sensors?
    4 - I'm also getting a poor as spark out of the coil whats that all about? I'm using a bosch 008 smart module ...
    5 - Ok so i've set the LC-1 so it puts out 0v-10afr 2.5v-20afr and made it gasoline 14.7 so why is my ecu still reading 34.7 AFR?
    6 - Suggestions for actually getting this bugger started?
    Thanks in advance
    Default Re: Want to start car!! Autronic SMC..LC-1..3TGTE.. Trigger pulse offset = Huh?
    Radar,
    What coils are you using? COP? or wasted spark?
    Do you need to tell the SMC what wide band sensor/input you are using? The LC1 stuff is not going to stop the car from starting,
    May 2007
    To get it started i've just gone for the single coil + dizzy with a 008 bosch ignitor module..
    figured out the o2 sensor so thats no biggie...
    And with any luck I think I may of finally figured out what I'm doing.. mayybe.. still would appreciate any input though
  1. 3TGTE crank trigger
    By racingjimmy75 in forum Tech and Conversions
    Last Post: 07-05-2010, 10:20 AM
