Results 16 to 18 of 18
Thread: *HELP* [TA23] New Excedy Clutch Won't Dissengage
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Default Re: *HELP* [TA23] New Excedy Clutch Won't Dissengage
    it wasnt sitting up on the flywheel locator dowel's when bolted up the 1st time?
    Years ago i brought a car where they had fitted the clutch rotated 1 bolt hole and it sat on top of the dowels and wouldnt engage/disengage properly.
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
    Tallahassee, FL USofA
    Quote Originally Posted by RAAAH23 View Post
    I dont know if this will help you.. but thats the PP assembly the top of the drawing is the flywheel side the bottom is gearbox side.
    OK. The distance between the clutch face and its mounting surface should be 1/2 the thickness of the disk, if the flywheel has a flat surface and is not stepped.
    If new one has less the 1/2, it isn't going to disengage very well. It seems like they should work just as well but they don't, I can't explain why the leverage is different.
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Yeah the mechanic explained that. Well good news the OEM is in and works fine. Looks like ill be able to hit the celica day after all
    Thanks everyone for your help its much appreciated. Looks like the PP was badly built.
    One again Thank You!
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
  1. JZA70 Clutch Problems
    By Shadow6 in forum Tech and Conversions
    Last Post: 15-01-2009, 09:13 PM
  2. Twin plate clutch - dramas
    By spiller in forum Tech and Conversions
    Last Post: 09-11-2007, 01:46 AM
  3. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 09:12 AM
  4. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 07:57 PM
