Ok, moving onto the injector harness.
If you were feeling cheap, you dont actually need to buy the harness from Greddy, as all the harness is, is a further 9 wires that clip into the plug that you get with the unit, so any wire with the right clip on the end will do, as long as it clips into the plug securely.
wire colours for this are:
Purple/Red - Signal #2
Yellow/Red - Signal #2
Orange/Red - Signal #1
Blue/Red - Signal #1
Black/Red - Injector Ground
Light Blue/Red - Signal #3
Pink/Red - Signal - #3
Green/Red - Signal #1
White/Red - Signal #1
The last two, in bold are apparently optional, i didnt see any harm in having them there, so i left them, but they can be removed without it causing the e-manage any distress.
ive uploaded the diagram for the connector, all the same wires should be joined before putting it into the car, as it'll save alot of headache.
ive also uploaded the ECU pinout for the JZA70 ECU (kindly taken from Supra6's site, full props to him/her) with my handwritten notes as to what wires need to be accessed, of the 30 wires (or so) of the e-manage, only 15 actually have to be taken from the ECU, the extra two pins on my diagram are for my additional Greddy knock sensor controller.
ive tried to keep the files as low in size as possible, at the sacrifice of size/quality, but they're still decent enough to do the job.
Thats it for that connector entirely, the next job is the ignition harness, this is where it gets a bit confusing.
Elmo.
