Get the injectors cleaned, they could be leaking.
Replaced the ECU coolant temp sensor as cambelt suggested. Use toyodiy.com to get a part number, and amayama.com to order one.
Open up the ECU and replace the capacitors with ones from RS Components, they tend to die over time.
Aux Air Valve will be an electronically controlled valve in the intake piping, somewhere between the AFM and the intake manifold. It is a throttle body bypass valve.
