Results 1 to 15 of 22
Thread: does an apexi SAFC actually make your fuel economy better
    Default does an apexi SAFC actually make your fuel economy better
    as above, does it work only when giving it to it or does it also work during daily driving
    any know some vague savings
    The boobs are back
    Default Re: does an apexi SAFC actually make your fuel economy better
    wrong section +1
    the SAFC can tune your Air Fuel map so power delivery is ironed out and "smooth" i.e. linearly so if you believe that you drive with less throttle because your car makes more power, then yea there is savings to be made..
    for me, on my car dyno tuned with a very linear air fuel map and power delivery, i'd say i save SFA... it's about as good as getting a fuel star.. if you believe it works, then yea it probably does
    the SAFC is only affective when the car is in open loop mode, ie 90% + WOT. At cruising speeds + light loads the car is tuned by the O2 sensor and the factory closed loop.
    In short, it will save you 2/5 of fk all at WOT and nothing anywhere else.
    RA23 - Twincharged
    JZZ20 - Daily
    kk, next question, does it give u much more power
    The boobs are back
    Yes in conjunction with exhaust/boost/cooler as it allows you to lean out the top end/high rpm rather than running really rich which of course increase power.
    as to an exact kw or hp increase that depends on your mods.
    RA23 - Twincharged
    JZZ20 - Daily
    got pics i wanna know what im buying
    mwawawawwawawawahhwhahwhahwhhahahwhhahwhhwaa
    The boobs are back
    Junior Member Grease Monkey Pr0j3kt_SuPrA's Avatar
    anyone willing to give me their SAFC settings so i i can base it upon that
    HP Guru Backyard Mechanic driftedmz20's Avatar
    Jan 2008
    still trying to tune mine properly
    dyno tune = safe way
    RA23 - Twincharged
    JZZ20 - Daily
    yeh i know but dont plan on goin ont he dyno till i get my FMIC fitted but otherwise im want to learn to play arnd with it.. i mean 1jzgte fairly rich stock
    Junior Member Backyard Mechanic alwaysRA23's Avatar
    go buy an aftermarket computer, and dont waist ur time/money
    Gumby. Yo.
    Quote Originally Posted by alwaysRA23
    gimme a few minutes and i'll PM u my bank account details so u can send me the $3k+ required for it
    The boobs are back
    Quote Originally Posted by Kedderz
    Highway driving sure... but around the city, esp in traffic, ECUs run in open loop a lot more.
    A good tune would then save a few $$s in fuel.
    EP Grease Monkey
    werd. they do make a difference. i have a zoom where they tested it on a JZA70, ended up going from 155rwkw to 173rwkw from just the SAFC. they did admit they were freak results and in that power range 10rwkw isnt asking to much
  1. fuel system
    Last Post: 02-11-2007, 12:02 PM
  2. APEXI SITC and SAFC on 1jzs
    By soara7mgte in forum Tech and Conversions
    Last Post: 18-11-2006, 09:54 AM
  3. Replies: 1
