You have to be careful with how you plum the boost control solenoid in, otherwise you might set it up so that the IACV actuator isn't able to close once it has been opened!....
If you using a solenoid with COM, NO & NC you would need to have the COM port going to the actuator and the NC connected to the pressure source.
When the ECU goes to open the IACV it powers the Solenoid so pressure flows from NC to the COM port to the actuator.
When the ECU goes to close the IACV it unpowers the Solenoid and the air that was used to open the IACV actuator is allowed to flow from the COM port to the NO port to atmosphere. If you don't allow this air to be released then the IACV won't be able to close (I.e. if you have the NC port closest to the IACV actuator)
Have you measured the resistance of your factory VSV?
If the resistance is OK then I would try to use a small bit of wire down the ports to unblock the port/s.
As another note if you still can't get it unblocked it is also it is possible to disassemble the VSV so that you can attempt to fix it / remove the blockage...
				 2jzgte help
 2jzgte help
