Results 1 to 4 of 4
Thread: Looking for 1GGTE head bolts
    Mar 2010
    Default Looking for 1GGTE head bolts
    Hey guys,
    Im chasing a set (12 i think) of head bolts for a 1GGTE. Ive called toyota and been told its $9 per bolt and they will be a few days to arrive from sydney. Does anyone know where i could get a set off the shelf in Brisbane??
    Default Re: Looking for 1GGTE head bolts
    been down this path, toyota is your only option unfortunately.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    You can use 2jz ARP main studs for head studs, ARP # 203-5405, according to kyle (6boost).
    I have discovered this week that the ARP head studs can be fitted without any machine work jamie, just drop them straight in. The only tricks needed are a deep 12mm 12 point socket, and you have to put the washers that go under the nuts on the head before you lower it down over the studs, or conversely, put the studs in through the washers after you've put the head on. I'd do option 1, takes all of 5 sec to put them in. Other than that, you don't need to do a thing. If anyone needs head or main studs, Jamie(Forcefed6) can suply them, I bought both my head and main studs from him, thanks jamie
    As for rod bolts, I'm not sure. I didn't bother, I expect it to destroy the piston before the bolts, they are a fairly stout bit of kit as standard anyway.
    http://www.toymods.org.au/forums/sho...84&postcount=4
    RA23 - Twincharged
    JZZ20 - Daily
    Mar 2010
    cheers man i got told this recently but wasnt sure what had to be done. Will these have to be the same torque and sequence as standard head bolts??
  1. 1JZ performance head build. Advice/help?
    By ReQuieM in forum Tech and Conversions
    Last Post: 09-07-2007, 09:08 PM
  2. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
  3. 3s-GE Head gasket
    By SilverSt162 in forum Tech and Conversions
    Last Post: 03-08-2006, 09:44 PM
  4. Are 4AGE head bolts supposed to use washers?
    By WHITCHY in forum Tech and Conversions
    Last Post: 27-06-2006, 07:13 PM
  5. 2T-G head bolts or studs - availability?
    By SeptemberSquall in forum Tech and Conversions
    Last Post: 19-12-2005, 10:13 PM
