Results 16 to 25 of 25
Thread: high temp epoxy
    Default Re: high temp epoxy
    QuickSteel, good for 360C (or so) and massive pressure =) its a 2 part epoxy/filler you can use it for steel repairs etc and also re drill it, whatever.
    I thought quicksteel was only good as a filler though not as a bonding compound?
    Firstly, I think I have forgotten to mention one important thing here. The transducer which I am attempting to glue to an alligator clamp is plastic not metal. So are the above recommendations still valid?
    30psi: Sounds like the super ear would be very helpful in your situation. I like DIY tuning so I think it is great
    QUICKEST 1JZ'S IN OZ
    Quote Originally Posted by Grant
    Ok, the stuff I bought was called "JB WELD" and it claims to fill and bond all sorts of metals and will hold up to 315 degrees C. As I said though, I haven't used it yet so can't vouch for its effectiveness.
    i've used the JB weld on many 'metal/alloy' things, it's great stuff. but onto plastic, hrmm. spose you jut have to try it.
    i've even seen the yanks use it to hold new/modified i/c pipes into i/c's...
    alright will go check it out. Mitre 10 should have it hopefully.
    Wezelton Grease Monkey
    wedge some screws n shit in there hahahah
    jokes
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
    Western Aus
    my suggestion would be to use the quiksteel to make a mount for you to attatch the plastic thingy.
    quiksteel is very strong, but it relies VERY heavily on a perfect surface, so if your going to use it, degreasing the area is a must, the more roughed up, and clean, the better.
    Quicksteel can be drilled, tapped, ground etc. its basically metal, but as an epoxy, its awesome.
    Eldar.O.
    can you post a pic of the two things you intend to join together?
    certain materials will not bond to certain glues, and sometimes you can use geometry instead to hold the buggers together.
    i used normal 5 minute araldite to hold together a radiator and a welch plug for a year, so it can stand up to some heat.. depends how you use it.
    Ok, I will get some pics up tonight
    Get some hi-temp exhaust gasket glue it will stick it. I've stuck pieces of aluminum on exhuasts with holes and they keep stick pretty tight.
  1. AE82 Electrical Question - Fuel & Temp
    By mlaser in forum Tech and Conversions
    Last Post: 29-03-2006, 10:58 PM
  2. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  3. High Pressure Radiator Caps - Opinions?
    By -GT- in forum Tech and Conversions
    Last Post: 19-02-2006, 01:44 PM
  4. 1JZGTE With Microtech LTX-12...what air temp sensor?
    Last Post: 16-02-2006, 10:38 AM
  5. RA/TA2x oil temp gauge sender..
    By celica-fiend in forum Tech and Conversions
    Last Post: 30-01-2006, 12:57 AM
