Yes it's drive-by-wire, although it's a little different as it uses a cable from the cabin to control it still. The throttle request sensor is built into the throttle body, I believe Wilbo modified his so the throttle plate was actuated directly by welding something up in the DBW part. I dont think his ever worked 100% on the stock ECU though which is why he's installing an adaptronic.
I got rid of the DBW setup on my vvti 2J by bolting up a non-vvti 2JZGTE upper plenum and throttle body etc.
One of the issues you'll run into if you do the plenum and throttle swap with stock ECU is idle control. The DBW setup controls idle via the throttle body, the non-DBW setup uses a traditional JZ ISCV at the rear end of the plenum.
I didn't have to worry about the DBW 2J ECU as I'm using an aftermarket ECU to run the show (Vipec V88 most likely, maybe an Adaptronic E1280S though), I also got rid of the TRAC from the non-vvti throttle I used by throwing it in the lathe and parting it off shorter which helped with a less-sharp bend for the cooler pipe.
http://www.purcellperformance.com/cressy/bay3.JPG
