Results 1 to 12 of 12
Thread: A304 converter QLD
    Jan 2007
    queensland
    Default A304 converter QLD
    who around brisbane modify's these converters.. of the few places i've tried they won't split the converter like you can on almost any of the older holden/ford stuff cheaply..
    everyone seems to want to build a new one.. $$$$..
    anyone know who around here does a higher stall converter for an A304 (1JZ)
    not after anything crazy.. but something around the 2800-3000 would be good..
    Jan 2007
    queensland
    Default Re: A304 converter & general q's QLD
    and 'shift kits' i know MV auto's do them.. what are they worth, what does a 'kit' include?
    Default Re: A304 converter QLD
    Mate, you'd be far better off ringing MV direct, he'll tell you everything you need to know.
    Facebook | LinkedIn
    A340e by the way, not A304
    Wilbo's JZA80
    Wilbo's JZZ12
    MV make a 2800rpm stall for the 1jz as well as shift kits. About $400 each.
    Jan 2007
    queensland
    yep i gave them a call and they do from 2500 to 4000 rpm converters ($395), and 3 shift kits (new valvebodys - $380).. and the bracket for the B&M shifter for $40.. the whole lot including frieght would be around a grand for a valve body, converter, and shifter bracket..
    i'm pretty sure the prices are around that i called on friday and wrote them down somewhere at work..
    wilbo - it's the MX83 style box, i thought i saw A304 written on the little tag/plate i might be mistaken though i'll double check , i'm a newbie to the auto boxes..
    On that topic, is the valve body replacements possible to do 'oncar'?
    Facebook | LinkedIn
    Quote Originally Posted by stradlater View Post
    Yes. But much easier with box out and upside down.
    Ah, yes, but pulling the gearbox out for me is a much harder task, so upside down might be the go. :-)
    Facebook | LinkedIn
    Jan 2007
    queensland
    the tag on the side of the box says 3041LE... excuse the very bad lighting and lack of anything close to a macro function on my iPhone..
    is this good or bad? when i spoke to Mike at MV, i said that i would be sending down our gear.. and waiting for it to be sent back up, not exchange (as he offered with addditional core deposit) as were in no hurry...
    anyone know if the valve body is interchangeable with the more common A340?
    Your box (a341e) has a different first gear ratio than the a340e. Otherwise they are much the same.
    Jan 2007
    queensland
    right-o! no worries then thanks for clearing that up... thought i was seeing things... i didn't know there were 2 different codes..
    ok so 304LE translates to a341e?
    i'm assuming the a341e is what the compliance plate has stamped on it?
  1. fitting new torque converter in 1jz
    Last Post: 14-09-2006, 05:47 AM
  2. Two cats in series
    By kugzs in forum Tech and Conversions
    Last Post: 10-08-2006, 08:32 PM
  3. Seating f'ing torque converter properly
    By 7mgte mx73 in forum Tech and Conversions
    Last Post: 22-01-2006, 11:27 PM
