Results 16 to 18 of 18
Thread: air in cooling system
    Tallahassee, FL USofA
    Default Re: air in cooling system
    Does the coolant overflow have 2 lines coming out of it? if hooked up wrong, it won't pull coolant back into the engine.
    The bubbles have to come from combustion or hot spots. The hot spot/s from low/slow coolant flow can happen from blocked passages, wrong HG or badcooling system setup.
    Apr 2010
    Quote Originally Posted by allencr View Post
    cooling system is al factory and looks to work ok.
    as far as head gasket its new metal type the head was done up aswell.
    i have decided to bite the bullet and tell him to go ahead and pull it apart.
    if its workmanship he will fix it . if other well.
    most people i have told think its the head cracked.
    I just had a problem with mine where the tube in the overflow bottle had a hole in it near the top and was sucking up air.
    So thats another possibility.
  1. 5MGE EGR Valve Cooling System Question
    By Art Racing in forum Tech and Conversions
    Last Post: 16-05-2009, 02:09 AM
  2. Unusual cooling system mod for a 20V
    Last Post: 03-07-2008, 11:56 PM
  3. Cry 02 Cooling System. Your opinions???
    By BLK1g-gte in forum Tech and Conversions
    Last Post: 22-09-2006, 12:47 PM
  4. Cooling Systems - Overheating Problems.
  5. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
