Results 1 to 6 of 6
Thread: 2 pins flasher relay
    Perth, WA
    Default 2 pins flasher relay
    i've got an 2 pins flasher relay for signal lights. one pin was labeled as "L" and another is "X". how this thing works actually? i'm connecting my signal lights completely ground up. can any one help me about this?
    Junior Member Backyard Mechanic ndgcpr's Avatar
    Default Re: 2 pins flasher relay
    should go in line with the load (lights). Usually (i am guessing its an older device as i don't think new ones did it) its 2 pieces of metal. they heat up from the load (so you need the right number of lights or it will change flash rates) and when they are hot the bend and disconnect the lights. then it cools down, bends back and reconnects. over and over again
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Perth, WA
    so meaning that one side is connected to a switched +12v, the other end is connected to the bulbs/lights. the flash rate will depend on the amount of current drawn by the bulb??
    My Missus is a Domestic Engineer BradW's Avatar
    Connect a fused ignition supply to the "X" terminal.
    Connect the "L" terminal to the common wire of your blinker switch.
    Connect the corresponding output wires from your blinker switch to your lights.
    Brad
    Old Corollas never die...
    My KE30
    Quote Originally Posted by CHB
    Yes i do. I would have guessed that L was the "load" but i wasn't sure but anyway bradw has confirmed it so try it out. but yeah you will find a simple low whattage light if you tryed tyo test it would probably not work or flash quick
    Perth, WA
    thanks a lot for the informations..
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. how do i wire a thermo fan thru a relay correctly?
    Last Post: 05-04-2006, 07:57 PM
  3. starter relay help
    Last Post: 19-12-2005, 10:01 PM
