Results 1 to 7 of 7
Thread: JZA70 - Can you use a clutch fan?
    Nov 2007
    Default JZA70 - Can you use a clutch fan?
    Has anybody tried to use a 1j/2j clutch fan on a JZA70 when changing the waterpump with a 2jz-gte One, and which shroud did you end up using, GA70/MA70 shroud?
    Which belt would I need to use for the clutch fan, can I re-use the one that was used for the Hydraulic fluid pump?
    Is there any clearance problems?
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default Re: JZA70 - Can you use a clutch fan?
    I'm using a jzz30 clutch fan in my jza70. Using a ma70 shroud. There's no clearance problems. IC pipes might get in the way of the shroud though. Some mods might need doing there. Original belt will work fine. Here's a pic of mine.
    1994 GZX90 Mark II 1GZ-FE V12
    Nov 2007
    Thanks,
    Did you need to use the pulley from the JZZ30?
    Yer you'll need the pulley from a jzz30/jza80.
    Nov 2007
    Thanks,
    Is the 2j motor longer than the 1j? Reason is that it might affect where my fan sits compared to yours, as in too far in the shrowd or too far away from the shrowd, since you got a 2j I'll be using 1j.
    Quote Originally Posted by Z2TT View Post
    Thanks,
    Nope Same length!
    2jz is taller than 1jz is what you might be thinking But the water pump is in the same spot so that won't effect you either
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2007
    Sounds good, anybody who has a 1j clutch fan, coupling and pulley that they would sell PM me.
  1. MA70 --> JZA70 Conversion
  2. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 09:12 AM
  3. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 10:30 PM
