Results 1 to 15 of 16
Thread: what to put in ta22? 4age 16 or 20 valve? or 4agze
    Apr 2010
    vic
    Question what to put in ta22? 4age 16 or 20 valve? or 4agze
    I have had my ta22 for a while now and have just got it back from the re-spary. I am contimplainting which 4a to put in. I have herd good things about all. I am having trouble deciding between the 16 valve the 20 valve or the 4agze. i am looking for the one which will fit in easy, I plan to completly re build the interanls with forged componets as i am planning to turbo it and run around 15 to 20 pound of boost so i need a strong block too. any information would be much apreciated.
    Default Re: what to put in ta22? 4age 16 or 20 valve? or 4agze
    For turbo on a budget go for the GZE. Should be no need to rebuild if you get a low km 1/2 cut and will be able to handle the 15-20psi you want. The 20v will just add complications and cost to a turbo setup without any real gain. IMO that is.
    Jun 2006
    I like 4AGE's .... a lot. why put one in a relatively heavy car like a Celica when you can fit bigger motors in there, that can make the same power as a 4a with less stress? 3SGTE, 1GG for example.
    Tasmania
    2zz-ge/t/z
    1973 TA22
    Apr 2010
    vic
    the reason i am going with the 4age is because from what reserch i have done they seem to be the easiest to put in, easy to find and parts are cheap. i have also head that putting in the larger ie heavier engine in can cause understeer and bad steering response.
    Tasmania
    4ag=cast iron block
    2zz=ally block
    1973 TA22
    Apr 2010
    vic
    i havent herd a great deal on the 2zz as far as i know they are a fairly new engine from toyota, but i dont know what they would be like fitting in the engine bay (mounts etc) as well as what box to put behind it. and although alloy is light, cast is strong can handle heat and high rpm as well as boost. not that a well built alloy wont but im not sure about the 2zz
    Tasmania
    there is a mob in the states called monkey wrench racing doing really good (and powerful) things with them, but as far as making one rwd there isnt much info kicking about.
    custom bell housing would be needed.
    4ag has been done many many times, easy conversion, lots of info.
    1973 TA22
    The easiest to put in is a 2T-G.
    A 1G is a 6 cylinder and will be a rather tight fit in the engine bay of a TA22.
    seeyuzz
    river
    Apr 2010
    vic
    thats why i think it would be best with the 4age / ze as there relativly easy to install and can make a respectable amount of power when done right. but which one is the question, 4agze makes sence as it is already supercharged, but i want it to perform when i put the turbo on. i only want to do it once
    7AGTE.
    Get some good rods (cheap enough and easy to get) and GZE pistons, a small port head, etc. A GT28 turbo and an Ebay exhaust manifold.
    www.billzilla.org
    Toymods founding member #3
    Apr 2010
    vic
    Quote Originally Posted by Billzilla View Post
    7AGTE.
    will defanatly keep that in mind, cheers
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    I've put a 4AGZE into a TA22, and it is a lot of work. If I had my time again I would have rebuilt my 2TG. My recipe would be:
    3T crankshaft
    88mm pistons ~ 10.5 compression
    Larger valves with porting
    Mild cams
    Change to electronic distributor
    Re-jet carbs
    2.25" exhaust
    You could do all of that for cheaper than a 4AZGE fitted. You could fit a 4AGE for cheaper, but there isn't much power difference between this and a healthy 2TG.
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    Jan 2007
    queensland
    isn't there alot of people just bolting on a dirty turbo setup with an upside down SR20 manifold onto relativley stock 2T's making decent HP... you can built a pretty strong 2T from a bin of parts from what i've been reading on these forums.. and chuck a turbro on it...
    and the TA22 celica isn't a 'heavy car'
    Quote Originally Posted by Valkyrie View Post
    use a later bigport 4age or smallport 4age and all you'll have to change when you build it is to some 4agze pistons and it'll handle your planned 15 - 20 psi forever. good intercooling and tuning of course.
  1. 4agze/ 4age 20valve? oil squirters?
    By 35rolla in forum Tech and Conversions
    Last Post: 16-02-2010, 07:31 PM
  2. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  3. delete plz
    By Wedged'86 in forum Tech and Conversions
    Last Post: 06-01-2008, 11:30 AM
  4. 4age valve & spring specs + mods
    Last Post: 25-10-2007, 06:09 PM
