Results 1 to 8 of 8
Thread: AE95/AE92 part interchange
    Brisbane
    Default AE95/AE92 part interchange
    Does the AE95 share its front seats with the AE92 variants? Is the back seat the same as the Seca?
    Assuming the drivers mirror is the same as the AE92 Seca as I can swap the doors between these two models?
    Jan 2007
    queensland
    Default Re: AE95/AE92 part interchange
    seca doors, yes... not 100% sure about the seats as the floor pans are quite different due to the 4wd...
    oregon
    I'm guessing it all depends on which AE95 you have....
    I have an AE95 sedan. The sedan shares most of its external parts(sheet metal, lights, mirrors, etc.) with the AE92 sedan.
    I just did some checking in toyodiy... part numbers for the base sections(left inner, and left outer) are DIFFERENT from the AE92 deluxe sedan, and the AE95 deluxe sedan. Chances are they will not easily cross over....
    Jan 2007
    queensland
    as he is in brisbane, i was assuming that he just had one of the very many AE95 wagon's that are floating around.. i have never actually heard of an AE95 sedan untill a few weeks ago when someone posted up something here who had one... wasn't in australia...
    the front end of the AE95 wagon is the same front end of the Seca... which differs slightly to the hatch..
    you should be fine to fit the mirrors from a seca to your ae95 wagon
    Sep 2009
    Seats will fit.
    Mirror should fit if its off a seca.
    Dash will fit
    not 100% sure on suspension components but i assume they also fit.
    there are many threads on the net confirming/disproving all of this, make sure you have a good search on google and twincam.org.au and also here just before you go out and buy/attain the parts.
    Case.
    Rear suspension components won't fit due to the live axle rear end, all mount points are totally different, they use a different floorpan section from the rear seats back.
    i have a ae92 and front seats form JDM ae101 levin bolt straight in.. so would expect ae95 to be same
    AE92 20V
    Sep 2009
    Quote Originally Posted by CEL_1JZ View Post
    Front seats will, i thought thats what the OP was asking... who gives a toss about the rear passenger?
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. 3sgte st215 on a corolla96
    By marmel in forum Tech and Conversions
    Last Post: 11-05-2010, 05:58 AM
  3. EPC owners please help me I need some part numbers...
    Last Post: 28-05-2007, 04:07 PM
