Results 1 to 9 of 9
Thread: 3sgte st215 on a corolla96
    Nov 2009
    attica
    Default 3sgte st215 on a corolla96
    hello from greece...
    i m trying to colect some info about install a 3sgte st215 from toyota caldina, to my corolla e10 1996...
    specially i need info about mounting...
    does anyone here droped this engine to this car?
    Nov 2009
    attica
    Default Re: 3sgte st215 on a corolla96
    this is the car and this is the engine.......
    Nov 2009
    attica
    does anyone know where can i find engine mounts from toyota caldina?
    Try www.trademe.co.nz and search for Caldina and you'll find a few that are being wrecked.
    You can also try your local toyota dealer.
    The part numbers you need are
    Front bracket
    part number on diagram 12311A
    part number to order from Toyota 12311-74200
    Front rubber insulator
    part number on diagram 12361A
    part number to order from Toyota 12361-16290
    Rear bracket
    part number on diagram 12321A
    part number to order from Toyota 12321-74440
    Rear rubber insulator
    part number on diagram 12371A
    part number to order from Toyota 12371-74351
    Right bracket
    part number on diagram 12315A
    part number to order from Toyota 12315-74130
    Left bracket
    part number on diagram 12372A
    part number to order from Toyota 12325-74370
    Left rubber insulator
    part number to order from Toyota 12372-74630
    Nov 2009
    attica
    but where is the other number for 12362? the mount of the passengers side
    thank you very much anyway...
    i m looking this mount at the pic below
    Nov 2009
    attica
    www.trademe.co.nz is only for nz and aus people...
    Right rubber insulator
    part number on diagram 12362
    part number to order from Toyota 12305-74290 or 12305-74291 as there are two numbers listed.
    With trademe if you can pay via paypal you might find someone willing to ship over to Greece if you ask so don't give up. Also try some NZ wreckers as they ship internationally in some cases complete engines.
    Nov 2009
    attica
    got any links from NZ wreckers ??
    i need the fuel pump and 2-3 motor mounts for the moment
    all from caldina st215
    Nov 2009
    attica
    i m finished with my project...
    i have a problem with the gearbox...
    i bought from england from mr2 turbo sw20 lsd a gearbox with 45000miles on it. the mr2 was 500hp.
    the guy that he sold to me dont know what lsd is it on it...
    my car is a modificate corolla and my engine is a caldina 3sgte st215...
    all went good...
    fix my car myself and it is very fast etc...
    BUT...
    when i want to turn it is very very noisy like a clung clung clung like broken irons...
    in the first time i thought that my driveshafts broken and i lost the balls of the driveshafts...
    but i checked many many times...
    the driveshafts are from the same mr2 and conect to celica st185 shafts and its perfect for corollas and mines work good with corect dimensions etc...
    when the car its on the air by jack and start it and the wheels turning ,it works perfect and no noises... with all the gears 1st to 5th...
    this noise it is doing also to the straight road when i turn the steering a little makes little noise... krrr trrr klr klr
    when i turn too much makes too much... clung clung clung....
    i thing the gearbox stuck...
    stuck the discs inside the lsd...
    or if i have a cusco lsd is the corect noise?
    toyota usa recomented to me to ptu 75W90 GL-3 LSD gearbox oil...
    i bought TRD 75W90 GL-3 LSD gearbox oil....
    i just want opinios what can i do with this...
    do u thing its a damage?
    or its a oil problem? i heart that cusco lsd works only with cusco oils...
    PLS HELP....
  1. st205 vs st215 3sgte
    By triptek in forum Tech and Conversions
    Last Post: 21-12-2012, 12:55 PM
  2. ST215 3SGTE into ST185
    By Diridius in forum Tech and Conversions
    Last Post: 02-07-2009, 03:46 PM
  3. ECU for ST215 3SGTE
    By Shifty in forum Tech and Conversions
    Last Post: 26-05-2009, 11:11 AM
