Results 1 to 4 of 4
Thread: Steering rack - do you know what this is for?
    Jun 2008
    Default Steering rack - do you know what this is for?
    I'm in the process of putting new seals into a leaky power steering rack on my 7MGE MX-83 Cressida. I just removed one of the boots and noticed in the rack shaft there is a hole. I can poke a length of wire down it into and along the shaft (see the photos). My questions are:
    (1) Is this hole to allow air to pass through to the other side when the rack is wound to full lock. I'm thinking the boot would blow up like a ballon if the air could not go somewhere.
    (2) How is the ball joint on the tie-rod shaft lubricated? I noted there was some oil in the boot but I don't know if it was oil for lubrication of the joint or leakage of power steering fluid past the oil seal.
    Default Re: Steering rack - do you know what this is for?
    ok I can't help you much other than to say that those ball joints are lubricated like wheel bearings are, they are packed and then held in there with the rubber boot.
    I can't think of any reason for that hole being there
    Jun 2008
    Thanks Sam. As it is a power steering rack there is an oil seal in the end of the housing so it is fully sealed. This is why I'm thinking the hole is a vent to allow air to pass through somewhere otherwise the air inside the boot has nowhere to go when it is extended or compressed.
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Yeah for sure it,s a pressure relief hole kind of the same as a water pump one if the pressure gets too high for watever reason the relief allows the pressure to come out without destroying anything else
  1. MX-83 Cressida Steering Rack & Pump Leak
    By petergoudie in forum Tech and Conversions
    Last Post: 13-01-2010, 08:42 AM
  2. SV-21 Camry steering rack in ST-162 Celica
    By jgcertified in forum Tech and Conversions
    Last Post: 22-12-2009, 12:48 PM
  3. SV21 Camry steering rack in ST162 Celica
    Last Post: 22-12-2009, 12:35 PM
  4. gz20 steering rack compared to mz20
    By VasH in forum Tech and Conversions
    Last Post: 04-01-2008, 02:53 PM
  5. AE86 "Cusco" quick steering racks??
    By oldcorollas in forum Tech and Conversions
    Last Post: 02-06-2007, 12:13 AM
